Friction from Steering
So over the past month i've noticed that when the car is cold, there seems to be a ot of friction whenever i'm turning the wheel. Its almost like there's so greasing needed but i have not idea where it'd be needed. Once the car gets warmed up (and i'm assuming the power steering as well) it runs normally. Any ideas what the issue might be?
Maybe he calls his Runner a car? Anyway, whatever you have, I have had the same thing happen to me on my Camry. It has only done it a time or two on very cold mornings. It would only do it just after cranking. I figured it was because it was so cold and I never investigated any further. It doesn't get cold here enough to worry about.
well forgive me on calling these beasts "Cars." lol well i guess it really is just cause it's cold, because once everythings warmed up then things are fine. i'll look into power steering slipage.
yeah def needed some fluid and in need of a fluid change. did quick refill and isn't making the noise anymore. hopefully there's not a leak. i'll be doing a fluid change soon. thx all.
If it hasn't been checked or changed in years it is not uncommon to have lost some over a really long time. It needs to be changed out from time to time just like any other lubricating product on your "vehicle".
Hydraulic fluids Oxidize, (rust), over time. Takes a long time with modern fluids but ten years and older are iffy especially Ford type "F" transmission fluid. Sometimes people put this in their power steering systems cause it is cheaper most places than regular power steering/transmission/hydraulic fluid.
live4soccer7
May 11, 2016 06:52 PM
scott90
Oct 4, 2015 09:21 AM
