Friction from Steering
Old Oct 23, 2006 | 10:58 AM
Tdubbs05's Avatar
So over the past month i've noticed that when the car is cold, there seems to be a ot of friction whenever i'm turning the wheel. Its almost like there's so greasing needed but i have not idea where it'd be needed. Once the car gets warmed up (and i'm assuming the power steering as well) it runs normally. Any ideas what the issue might be?
Old Oct 23, 2006 | 12:21 PM
Flash319's Avatar
This is a truck forum not a car forum. But it sounds like your fluid is just cold or your power steering belt is sliping.
Old Oct 23, 2006 | 03:17 PM
Nic's Avatar
Nic
Maybe he calls his Runner a car? Anyway, whatever you have, I have had the same thing happen to me on my Camry. It has only done it a time or two on very cold mornings. It would only do it just after cranking. I figured it was because it was so cold and I never investigated any further. It doesn't get cold here enough to worry about.
Old Oct 30, 2006 | 10:12 AM
Tdubbs05's Avatar
well forgive me on calling these beasts "Cars." lol well i guess it really is just cause it's cold, because once everythings warmed up then things are fine. i'll look into power steering slipage.
Old Oct 30, 2006 | 11:11 AM
spudrunner's Avatar
Try changing out your steering fluid. Changed mine last week and it was a nasty brown color.
Old Nov 1, 2006 | 11:20 AM
Tdubbs05's Avatar
good idea! i'll check into that.
Old Nov 1, 2006 | 11:59 AM
MMA_Alex's Avatar
changing the fluid is a good idea. It may just be that the fluid is junky or low. I'd also check the condition, and tension of the belt as suggested above it may be slipping.
Old Nov 6, 2006 | 04:04 PM
Tdubbs05's Avatar
yeah def needed some fluid and in need of a fluid change. did quick refill and isn't making the noise anymore. hopefully there's not a leak. i'll be doing a fluid change soon. thx all.
Old Nov 6, 2006 | 04:13 PM
rezrunner92's Avatar
If it hasn't been checked or changed in years it is not uncommon to have lost some over a really long time. It needs to be changed out from time to time just like any other lubricating product on your "vehicle".
Hydraulic fluids Oxidize, (rust), over time. Takes a long time with modern fluids but ten years and older are iffy especially Ford type "F" transmission fluid. Sometimes people put this in their power steering systems cause it is cheaper most places than regular power steering/transmission/hydraulic fluid.
ladybugRC
458
Aug 21, 2020 10:41 AM
live4soccer7
May 11, 2016 06:52 PM
scott90
Oct 4, 2015 09:21 AM
ktm192k
Oct 1, 2015 08:47 AM
gentry
Sep 28, 2015 06:16 AM
