Flywheel broke off
Old Mar 29, 2009 | 01:34 PM
  #41
Matt16's Avatar
Originally Posted by 91Toyota
I already tried that method! lol.
I have the same exact extractor and everything. Maybe I did it wrong? I don't know.
I'll give that thing 1 more shot!
Thanks Superbleeder!
If you're having trouble drilling a straight hole, try drilling a pilot hole with a tiny bit (3/32", 1/8" ), then drilling with progressively larger bits. With the tiny bit, you'll be able to drill out a accurate hole in less than a minute.
Old Mar 29, 2009 | 02:37 PM
  #42
91Toyota's Avatar
Thanks guys!
Anyway...i've tried the extractor and reverse drill method on 4 bolts...no luck...i've successfully drilled out 4 holes though. I used a little bit smaller drill bit then the size of the hole was and drilled a little off on each. Anyway, once I drilled through...I could easily remove the remaining bolt/stud with a screw driver. I do see nice clean threads though! I have a feeling everything will be alright!
Anyway, any idea what I should do to repair the threads? I'm thinking each hole will have 80% threads left all on one side...so I will buy a tap and die and clean the threads and just buy oem flywheel bolts and I should be okay right?
Again...thanks!
Old Mar 29, 2009 | 03:09 PM
  #43
86Toyrunna's Avatar
good to hear your wining the battle.. if you have access to a small propane torch you can try heating the bolt a lil bit.. blue and red locktite can be disolved with heat, not so much with the green stuff.
Old Mar 29, 2009 | 05:16 PM
  #44
91Toyota's Avatar
Yay! I got all the bolts out!
Now I need a set of original flywheel bolts. I'm kinda proud of myself
The last two bolts came out exactly like the thing iamsuperbleeder used. I bought one and tried it a on a couple of these bolts but it worked flawlessly on the last two! Glad I bought it!
Old Mar 29, 2009 | 05:21 PM
  #45
iamsuperbleeder's Avatar
good job!
glad they worked for ya they're well worth every penny
Yeah get some REAL bolts for that thing
honestly, I'd check the dealer; how much could a handful of bolts cost, really?
Old Mar 29, 2009 | 05:28 PM
  #46
91Toyota's Avatar
They wanted $50 for them
Old Mar 29, 2009 | 05:36 PM
  #47
dayamn, really?
some auto parts stores can order them too
most just carry the common ones in stock, a lot of GM ones, but I'd check to see if maybe than can order some for the Toy
Old Mar 29, 2009 | 05:50 PM
  #48
91Toyota's Avatar
Originally Posted by iamsuperbleeder
dayamn, really?
I can get a set of ARP bolts for $30...might as well go with them...or get a set from LC for $20...and of course I would have to pay for shipping and handling too! lol
Old Mar 29, 2009 | 05:53 PM
  #49
$30 for the ARP's isn't too bad
but if you have to pay shipping on either, the LC bolts will work just as fine too
all you need is stock replacement; it's not like you're running a crazy tuned high HP 22r there
I mean the bigger, better, and stronger bolts will never hurt, but their's a point where you're just throwing money away
Old Mar 29, 2009 | 05:55 PM
  #50
91Toyota's Avatar
lol...80hp! I thought I was in the 60's
I'll call around and see what I can get for cheap
Old Mar 29, 2009 | 06:00 PM
  #51
don't feel bad, on the show "Trucks" I watched them dyno run a Cherokee today, and the 4.0 in it made a whoping... 35HP of course that was due to several mechanical issues... but still, lol
Old Mar 29, 2009 | 08:33 PM
  #52
91Toyota's Avatar
HAHA...I would have laughed so hard. Probably would have fell off of my chair
camel_65@hotmail.com
Oct 3, 2018 06:11 AM
Obmi
Oct 4, 2015 11:30 AM
hiluxinargentina
Sep 30, 2015 05:51 PM
puddlepirate
Sep 29, 2015 08:02 PM
mtrdrms
Sep 26, 2015 07:12 AM
