Fitting a cherokee tank where the spare would go
I'm in the process of adding an auxiliary tank to my 92 Hilux Surf. There is plenty of room between the rear axle and bumper with the rear tire carrier. Does anyone know if it is "ok" to remove some or all of the cross member where the spare tire would attach to? Or move it, or replace it with something more flush to the bed.
With the cross member gone I could get the tank up another 4-5 inches.
i was thinkin about doing this... is there a build up thread I could reference. My questions pertain more to when do they use that tank... do they pump it to the primary tank as the primary tank is used, or is there a 2nd line... i'm very interested in this
From: Nashville TN. I can help you if you're close BUT NOBODY CAN HELP YOU IF YOU DON'T FILL YOUR LOCATION IN!
Hey, I think that'd make a sweat behind the cab tank for a flatbed too...
Where's the neck? And can you turn it and it fit up higher between the rails more?
oh heck yeah! Just like a twin tank ford!
still have to get gas in it though... hmmm
too bad you can't fix the tank where it'll flow into the other one, and use a low pressure positive air pressure line to blow air into the aux tank's vent, and push the fuel into the primary...
Or, a fuel pump setup like a lawn mower has. It's a tiny disk, sorry diaphragm, that flutters with vacuum and pumps fuel.
http://www.quickieparts.com/808656-b...fuel-pump.html
The cherokee has an internal pump so you could easily plumb it to fill your existing tank or buy a fuel selector switch such as this. http://pollak.thomasnet.com/viewitem...-driven-valve?
The filler neck is at the back drivers side. The tank has a slight taper at the back for a better departure angle but I'm probably going to turn it around so that the filler neck is on my drivers side (RHD).
Jun 1, 2021 01:51 PM
JustMike
Apr 21, 2016 07:08 PM
FS[SouthEast]: 87 toyota pickup 4x4 22r
Yota.Jay
Jul 26, 2015 05:50 PM
crashburnoveride
Jul 10, 2015 06:39 AM
skoti89
Jul 8, 2015 12:05 AM
