first time doing front brakes, pointers?
Old Jun 20, 2006 | 08:14 AM
91RN81's Avatar
hey guys my front rotors and pads are shot and i don't have the money for labor to install the brakes so i'm going to take a stab at it even though i have never changed brakes before. I bought some brembo rotors from tirerack only $29 a piece! and some toyota pads. What tools will i need and any pointers and or detailed info would be great, just don't anything falling off going down the road, lol. thanks..
This install will be on my 1991 toyota std cab 2wd truck.
Old Jun 20, 2006 | 08:40 AM
AH64ID's Avatar
You will need brake cleaner, brake fluid (though it can be done without removing the brake line... You will also need the large spindle nut socket, 54mm??? I dont remember, but its big..but could be smaller on your 2wd... get a chiltons and go from there
brakes are fairly easy, good luck.
Old Jun 20, 2006 | 11:32 AM
Kyle95sr5's Avatar
hey man, i recently just did the same thing. here are some of the websites i found while searchin for info about it. might as well replace the rears while u are doin the fronts.
https://www.yotatech.com/forums/show...ghlight=brakes
http://www.4x4wire.com/toyota/maintenance/rearbrakes/
-Kyle
Old Jun 20, 2006 | 11:48 AM
celica's Avatar
Since you are 2wd it shouls be a piece of cake.
remove the wheel, pads, caliper - you won't need to remove the brake line - this will make it easier. Bang off the old rotor, slide on the new one. - you shouldn't need to remove the spindle nut on a 2wd, the rotor simply slides over the wheel studs (someone correct me if I am wrong). The rotor will sometimes be a bugger to get off - I have had to use a sledgehammer int he past - good luck.
Old Jun 20, 2006 | 12:47 PM
Kyle95sr5's Avatar
not tryin to steal a thread here but im gonna be buying new rotors for my 4wd in a month or so Matt, would the same procedure work for mine or does somethin else need to come off as well.
Old Jun 20, 2006 | 12:57 PM
leebee's Avatar
check through this, it should answer your questions and show you how things come apart and go back together.
http://personal.utulsa.edu/~nathan-b...akesystem.html
lee
Old Jun 20, 2006 | 12:58 PM
AH64ID's Avatar
There is a spindle nut that needs to come off as well...
also, repack your wheel bearings at the same time
Old Jun 20, 2006 | 02:01 PM
celica's Avatar
The 4wd are more complcated to due due to the different hub design - best to look that one up in a manual as there is a specific torque on the bearings.
Old Jun 21, 2006 | 09:47 AM
91RN81's Avatar
the chilton's manual says something about setting the bearing pre-load what is that all about? and will i need any oversize sockets for removal of the rotor? thanks
Old Jun 21, 2006 | 10:16 AM
TNRabbit's Avatar
I've always been able to judge the preload without a scale pretty accurately. You basically have to set the nut tight enough for a scale to pull XX pounds from the lug bolt (i thing 35 lbs) in order to get the wheel tight enough to avoid it loosening up during driving.
Socket it huge; invest in one from Sears now (I think it's 52 mm?).
Old Jun 21, 2006 | 10:19 AM
Asha'man's Avatar
54mm or 2 1/4", I paid $22 at Sears.
http://www.off-road.com/toyota/wheel_bearing.html
Brian
Old Jun 21, 2006 | 10:51 AM
AH64ID's Avatar
Brian
I got mine from either NWOR or Downey, its not an actuall socket, but made spec for toyota hub work...
Old Jun 21, 2006 | 02:05 PM
celica's Avatar
Remeber his is the 2WD - I don't know if the nut is the same size & I don't think it has to be removed to do the discs. I have yet to remove one other than on a 4WD
Old Jun 21, 2006 | 05:36 PM
TNRabbit's Avatar
Sorry, I was addressing that to the guy with the 4wd.
Old Jun 21, 2006 | 08:15 PM
91RN81's Avatar
so anyone know what size socket i need for removing the rotors?
Old Jun 23, 2006 | 09:13 AM
celica's Avatar
A big hammer! - read my first post again. Once the wheel is off & the caliper the rotor just slides off the wheel studs. Often it is very tight & slightly rusted on - hence needing to hit it with a hammer. The only thing that really holds it on is the caliper being bolted to the spindle in the back & the wheel being bolted to the wheel studs.
TNRunner88
Jul 1, 2015 08:00 PM
miceal383
Jun 29, 2015 12:27 AM
Iceman4193
Jun 28, 2015 10:30 AM
YotaGreenhorn
Jun 27, 2015 07:00 AM
