Famous "high idle/surge" culprits!
Old Apr 15, 2008 | 07:31 PM
  #61
rowdy235's Avatar
I have white stuff in my air cleaner holder, its caused from blowby oil getting in there and then condensation. I'm not sure how it'd get in the TB though
Old Apr 15, 2008 | 07:34 PM
  #62
91Toyota's Avatar
Yeah, its right at the front. It comes from the like that goes from the VC to the throttle body. Here's a pic...horrible looking but it is the best I've got.
Old Apr 15, 2008 | 09:14 PM
  #63
thook's Avatar
Coming the "like" that goes from the VC to the throttle body? What's the "like"?
Best I can tell from the pic, that doesn't look like foaming oil. That looks like oil when mixed with water....like rowdy is saying.
Old Apr 15, 2008 | 09:17 PM
  #64
91Toyota's Avatar
lol. Not sure what I was writing. It goes from the VC to the throttle body (that little port). I was going to drain some oil and clean that and then drive it and see what it looks like but so far it is not looking too good.
Old Apr 15, 2008 | 09:55 PM
  #65
thook's Avatar
Yeah, that would be the breather line. Ehem....blow-by! Probably from cyl.3.
Does that milky bird doo-doo stuff smell like gasoline at all?
Old Apr 16, 2008 | 03:12 PM
  #66
91Toyota's Avatar
Not sure. I haven't had a chance to stick my finger all in it and rub it on my nose ( ) but I haven't smelled it yet. Maybe it is just blow-by though. I will give it a sniff in a little bit then drain some oil.
Old Apr 16, 2008 | 05:15 PM
  #67
thook's Avatar
Might give a taste test, while your at it...
Old Apr 16, 2008 | 07:09 PM
  #68
91Toyota's Avatar
lol...I don't think so
I still haven't done it yet. I was too busy doing some mudding...lol. I am surprised how much I can go through with a 2wd. Some people really bash 2wds at my school and always dare me to go through stuff...I haven't got stuck yet
Old Apr 16, 2008 | 08:39 PM
  #69
91Toyota's Avatar
Alright. I smelled it and it seems kind of sweet. Can't say it has a strong gas smell but maybe a little. I did not taste it though as I already have a sore throat. I don't think it is either gas nor coolant. I did drain some of my oil and I am going out to see if that bird took a shIIt in my intake...lol. Damn birds!
Old Apr 17, 2008 | 05:47 PM
  #70
91Toyota's Avatar
Alright. I looked in the intake and the stuff was still present.
I really don't think I have a blown HG now.
So, what's next? Should I just look for a new intake and everything?
Old Apr 17, 2008 | 06:04 PM
  #71
91Toyota's Avatar
I did find a complete 22re efi setup w/ computer and harness and everything. It is $250 though
Old Apr 18, 2008 | 01:44 PM
  #72
thook's Avatar
Sweet? Come on, man. You have a blown headgasket. Coolant is the only thing that would even remotely smell sweet. Unless, the birds have been eating cookies again?....
Did you drain any oil, yet? Look in your oil filter, too.
Old Apr 18, 2008 | 01:46 PM
  #73
thook's Avatar
$250 is cheaper than the rebuild you'd be looking at.....if you don't have to do any work to the replacement motor.
Old Apr 18, 2008 | 02:11 PM
  #74
TomThumb's Avatar
Just a thought a friend of mine had a 22RE 4runner with surging issues turned out it was the thermostat staying closed as a result the temp sensor was giving incorrect readings and messing up the ecm. worked for him just a thought
Old Apr 18, 2008 | 02:46 PM
  #75
91Toyota's Avatar
It's not really sweet. It's just a funny smelling smell...lol.
I am not sure if I am loosing coolant or not. Maybe my reservoir is leaking.
Is there a for sure way to tell if I have on or not?
Old Apr 18, 2008 | 02:56 PM
  #76
thook's Avatar
Generally, the best way to tell if you're losing coolant is if the radiator is low, but sometimes if you put your arms around the truck and quietly and sweetly ask,"My darling, what is ailing you so?"....the truck will tell you. People don't believe me, but it's true. I have a very close, intimate relationship with mine. I stroke her fender....she purrs.
Seriously, though.....you need to check that filter and oil, okay?
Old Apr 18, 2008 | 04:07 PM
  #77
91Toyota's Avatar
I checked the oil a couple days ago. It was black as could be. 500 miles and it is black (I did put a additive to fix my compression and it is working on that one cylinder!!!). I did just change my oil (500 miles ago) and it was black. It was not any green/brown...just dark black. I know what coolant looks like in oil (for example my car)...
I know what it looks like to have a blown head gasket...and I have no signs of it. I'm not losing coolant out of the radiator (it is always full) but I find myself filling up the resevior. I've done it twice.
I did take the Auxiliary Air Valve off and I have it sitting on my work bench. I don't know if I can check it or take it apart. Thanks
Old Apr 18, 2008 | 05:11 PM
  #78
DCYota's Avatar
Alright, so maybe I missed it..but what IS the story with your #3 cylinder?
Old Apr 18, 2008 | 06:07 PM
  #79
91Toyota's Avatar
Well, not entirely sure. It started when I bought my truck. Ran great. Nothing wrong with it. So, I bought a tach and immediately after I installed it I wanted to see what it had. So, I tried to get it to redline. And at 4700-5k it acted like a rev limiter. Took the VC off and I could stick my finger in between the rocker/valve...so I thought the valve was stuck. So, took my head off to fix it and it wasn't stuck. I bought rings and everything to take that piston out but decided not to. I put it back together and now I am having idling problems.
The compression of my cylinder was 40. I put seafoam in and it raised it to 48 or so. Then I put ARX in and it raised it to 62/63. It's coming up, but slowly.
I can't tell you exactly whats going on with it. I was thinking an excessive amount of sludge in the ring packs. All I can say is this engine has taking A LOT of abuse from me in the past months. Red line a lot, rev limiter for 30 seconds. Shift at 6k in second. Down shift to 2nd doing 55-60 and then a loud pop and blue smoke...I thought it was toast but it still runs!...lol
Old Apr 18, 2008 | 06:22 PM
  #80
DCYota's Avatar
Well, no one can say that you're afraid to test your truck's limits
