Faint low knocking sound
Old Aug 17, 2012 | 04:30 AM
sechott's Avatar
88 v6 manual, I hear a faint knock at low rpms doesn't matter if engine is warm or cold. I can't hear it from the bottom of the oil pan but it sound the strongest from the front drivers side close to the distributor. The only thing I have done was change the oil a week ago. I also hear a growling noise that fades as the engine warms.
Afaik this engine still has the factory timing belt it has low miles <60,000. My timing has a slight deviation about a 5-8* bounce and a mild shake at idle. I'm thinking a new belt will solve my issues. The shake, timing bounce and knocking noise seems to be in unison.
Old Aug 17, 2012 | 04:34 AM
sechott's Avatar
I am not too sure about the miles it is a little unbelievable, but that is what is registered on the odometer. Had mechanics tell my that from they can see it looks honest.
Old Aug 17, 2012 | 05:28 AM
sechott's Avatar
I went out to take a look at it this morning, couldn't hear a knock at all but I did see some coolant ontop the water pump area, that explains the growling. Since I need to replace the pump I will go with a belt change too. I did some stethoscoping couldn't hear anything knocking maybe just a imaginary thing.
Old Aug 17, 2012 | 07:05 AM
Red Wagon's Avatar
Your power steering pump can make that noise too. There is a valve on it that can go. I've had two go on me in a year.
montanatruck
Feb 26, 2017 07:07 AM
raptor510
Aug 19, 2015 02:15 PM
Jeffreynmandy
Jul 18, 2015 08:26 AM
raiderhawks00
Jul 8, 2015 06:23 PM
MTLroadierunner
Jul 6, 2015 12:17 PM
