Factory ac plug outlet
Old Dec 20, 2009 | 07:47 AM
ToyoTech559's Avatar
i have a 1988 SR5 V6. looks to be fully loaded minus the inclinometer. anyways my parents have had this thing since brand new. now they have moved on to a newer truck. i pretty much took over to make it my off road vehicle only. anyways i was cleaning it up to make it look like new again and found what looks to be a ac plug in right next to where you would pop the gas door. i hit it with a tester and shows it has power on one side and ground on the other. i grabbed a plug to see if it fits, i didnt plug it in all the way but it does fit.
anyone know what this is used for? i looked at the wires behind it and i doubt it can run anything strong.
Old Dec 20, 2009 | 08:11 AM
weaselman's Avatar
check out my thread..
https://www.yotatech.com/forums/f116...g-dash-197894/
Old Dec 20, 2009 | 08:27 AM
eighty5yota's Avatar
i have one! i still have the light too.. poor output but its better than nothing
Old Dec 20, 2009 | 08:44 AM
thanks weaselman. not what can i use it for since i dont have the light anywhere
Old Dec 20, 2009 | 10:00 AM
weaselman's Avatar
no problem, i cut mine out. and now use the ground for something else and the power wire for a power to my extra fuse box. (it has power constantly)
Old Dec 20, 2009 | 03:37 PM
89RUNNERFFD's Avatar
I just gutted an 89 1st gen, SR5 and that was one of the items grabbed.Had to pull the front dash wire loom for the complete install of Power windows ,cruise control and others.
Old Dec 20, 2009 | 03:57 PM
weaselman's Avatar
yea. mine had power windows from the factory and the relay went out. so i looked at the diagram to figure out where the relay put the 12volts and put 12 volts there. now they work perfectly.
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
steve miller
Oct 10, 2015 01:40 AM
94whiterunner
9
Sep 22, 2015 07:28 PM
skebe22RTE
Jul 31, 2015 02:03 PM
skoti89
Jul 8, 2015 12:05 AM
