Engine Troubles 22RE
Old Mar 2, 2008 | 10:41 AM
DanStew's Avatar
I am fortuante to not throw a rod, the block is probably rebuilodable, i will try to trade it for something later on.
Old Mar 4, 2008 | 07:04 AM
rdlsz24's Avatar
So in the end Dan it looks like we did have pretty much the same problem
Rob
Old Mar 4, 2008 | 07:24 AM
DanStew's Avatar
Right now i am trying not to totally go nuts... i have been looknig at what it needs, and for some reason i am all of a sudden needing a new 261 cam and a heavy flywheel for the truck. I have to step away from the internet catalogs
Old Mar 4, 2008 | 08:57 AM
rdlsz24's Avatar
Nice. I'm planning on just dropping in a replacement engine with somewhat low mileage. I was planning on selling this truck at the end of summer anyway because we are expecting our first kid in September and my wife needs a new baby hauler so the Yota has to go. In a couple years when my car is paid off I am hoping to get a 2004+ Tacoma with a back seat.
Rob
Old Mar 4, 2008 | 05:36 PM
  #25
Targetnut's Avatar
It's sad news, but look at it as an opportunity.
when you are through, you'll be set.
as you go through this new engine pay close attention to detail to make sure you end up with a worthy piece.
Old Mar 4, 2008 | 07:37 PM
  #26
Matt16's Avatar
What inside the motor is brass/ brass coloured? What might the problem be?
Old Mar 4, 2008 | 07:46 PM
  #27
CW's Avatar
CW
Main bearings, rod bearings, cam bearings...........
Old Mar 5, 2008 | 05:34 PM
  #28
HelliphinoN8's Avatar
Don't get so nutty on the rod knock. It sounds to me like the timing tensioners are gone and you have about two revs before they break thru into the water galleys. These damn 22re's are hard to figure out sometimes. Othertimes they're easy. Google it man. You'd be suprised about how much crap you'll learn.
Old Mar 5, 2008 | 05:58 PM
  #29
DanStew's Avatar
I just put in a new timing set about 1-2 months ago.
Old Mar 15, 2008 | 08:19 AM
  #30
socsmm6's Avatar
dan did you ever find out the problem with your truck? my sons truck is making the same sound. he said it got hot last night and thats when the noise started. I thought the video was of his truck, it is even red. he has a heavy right foot, he will learn the hard way.
Old Mar 15, 2008 | 09:00 AM
  #31
DanStew's Avatar
I beleive it is the main bearings gone out. I didnt pull the motor out yet. I just broguht a second block i had to the machine shop so i can rebuild it. I will have it apart in about 3 weeks to find out what it was. But I found more small chunks on my dipstick when i checked again last weekend for something. No that large, but little chunks big enoguh to know it is not normal wear and tear
Old Mar 15, 2008 | 03:20 PM
  #32
toyotatom93's Avatar
I also am having an issue with some knocking...and thinking it might be a rod or main bearing just makes me sick.
Can I just ask if the knock was there as soon as you start it up or did it have to warm up first?
Old Mar 15, 2008 | 06:49 PM
  #33
DanStew's Avatar
It was at start up. I thoguht at first it was timing chain but i changed that and it kept on. Probably could have lived with it for a while, but that last long trip at higher RPMs just killed it. Better now than at an even worse time. So i will rebuild it and have a truck to not worry about the engine.
Old Mar 15, 2008 | 10:16 PM
  #34
iamsuperbleeder's Avatar
This may be a redundant question, but do you happen to have a mechanical oil pressure gauge lying around that you could hook to the motor and check the pressure while it's running? I had an old Cherokee that yes, had a low oil pressure light, but did not come on when my oil pump shot out. Same symptoms; metal flakes in the oil, all the knocking, etc (not sure how I grenaded the pump like I did, but sure happened). If it's possible, I'd surely check that before pull'n the motor... just food for thought.
Colington
Mar 8, 2020 09:51 AM
mskalmus
May 28, 2017 07:51 AM
steve miller
Oct 10, 2015 01:40 AM
Avenged
Jul 9, 2015 07:55 AM
cyclist231
Jul 7, 2015 12:56 PM
