Engine mounting advice
Old Jan 23, 2016 | 03:44 PM
4by4yoter's Avatar
About to attempt to mount my rebuilt 22re into my 86. Ive done engine work but have always had help mounting an engine and have never done a 22re do you have any tips before i attempt this tonight? Thanks
Old Jan 23, 2016 | 04:07 PM
Terrys87's Avatar
When I get the motor close to the transmission, I have two long thing Phillip screwdrivers that I run thru some holes on the engine block and transmission to act as guide dowels.
I look at the gap between the motor and transmission and try and keep the gaps even as I get them closer together. Getting the transmission shaft into the pilot bearing is usually the hardest part. Once you get it in and the motor and tranny are together, it usually goes alright after that.
Getting the bolts at the top of the transmission at the 1 and 11 oclock position can be a pain. I use a long extension with a swivel for those.
Old Jan 23, 2016 | 04:18 PM
4by4yoter's Avatar
Thanks for the advice. My transmission seems to have dropped a little after removing the old block. Will i have to jack it up to get it to sit right? I figured the hardest part would be stabbing the transmission back into the motor.
Old Jan 23, 2016 | 04:33 PM
Terrys87's Avatar
If it has dropped, I would raise it back up with a floor jack and may a block of wood. You will need higher up. If it is sitting on the stablizer bar, I think it is to low. The motor will probably sit on the engine mounts and be to high for the transmission if I remember right.
Old Jan 23, 2016 | 04:37 PM
Terrys87's Avatar
I just did my 85 transmission and forgot that the 85 dont have the stabilizer bar. I also helped on an 86 that does have the stablilzer bar. The motor being to high could still be a problem if the transmission is to low though.
Old Jan 23, 2016 | 11:40 PM
wyoming9's Avatar
Red face
Might be to late to help !!
I would not wish having to do this alone on anyone..
2 people is alright 3 is even better.
Best of luck
Old Jan 24, 2016 | 02:19 AM
SwVa_1stGen's Avatar
Best of luck
Im just the opposite, I would rather no one else be there
Old Jan 25, 2016 | 11:50 AM
4by4yoter's Avatar
Thanks guys got it in now to hook up everything
Old Jan 30, 2016 | 01:32 PM
4by4yoter's Avatar
Need help guys. My water pump pulley wont line up with the studs seems like it's completely wrong the holes dont line up whats the deal here?
Old Jan 30, 2016 | 07:02 PM
4by4yoter's Avatar
No one?????
Old Jan 30, 2016 | 07:20 PM
4by4yoter's Avatar
Nvm found the right pulley..lol
Old Jan 31, 2016 | 07:34 PM
4by4yoter's Avatar
Big problem here guys. Does my lower alternator mount sit behind the drivers mount?
Old Jan 31, 2016 | 08:05 PM
Chaser Johndoe's Avatar
nothing sits between the mounts. your alt mounting bracket goes over the drivers motor mount. do you have a chilton or haynes? also there is a factory service manual on here.
Old Jan 31, 2016 | 08:41 PM
4by4yoter's Avatar
Based on what im seeing it definitely goes under the motor mount. It wouldnt fit right if it sat over the mount. Where is the service manual on here? Or show me a diagram or something
Old Jan 31, 2016 | 08:46 PM
4by4yoter's Avatar
Under...
Old Feb 1, 2016 | 05:35 AM
oh yes it goes under on the motor side. i thought you were talking frame mount and motor mount. in between that.
there is a sticky at the top of the forums for the fsm.
Old Feb 3, 2016 | 09:32 PM
4by4yoter's Avatar
Where do these power steering lines lead to?
Old Feb 5, 2016 | 07:02 PM
4by4yoter's Avatar
Guys please help ill mail you money lol this is the last thing I need to know and I need to know where this ground wire goes! Its the last 2 things until i can start up my truck after 8 long months!
Old Feb 5, 2016 | 07:32 PM
Grego92's Avatar
Not my engine.....
Just search 22re grounding wires, I remember there's a post where they are located/attached. I THINK that is the one that attaches to the manifold somewhere.
Old Feb 5, 2016 | 08:00 PM
4by4yoter's Avatar
Thanks for the direction on power steering lines. Ive seen every grounding thread available. The one that connect the intake comes from the loom the one in my pic is on the passenger fender side of the engine on the body and there absolitley no info AT ALL on this ground. Someone please chime in as im really trying to get this thing running tonight
