emissions!!!!
Most common for high CO would be O2 sensor failure. Since its an engine swap tho, almost anything could be wrong. Is this the trucks first emission test since the swap? Or has it passed with the 3.4 before?
Unless you have the knowledge and the equipment to test O2 sensors etc I'd find a shop the specializes in emission failures and let them diagnose it.
Too much fuel eh , injectors dirty and leaking , old clogged air filter , aftermarket plugs with factory .044" gap when it supposed to be .031 , low compression ?
Not burning it or too much , that is the question .
Yep just pull some vacum lines loose and lean it out ROFL
was just curious which means I have no idea since I have never seen a 3.4l (crying) so disregard my post concerning the plug gaps as I do not even know what spec is for that motor.
Well I don't even understand which numbers are his and which are the allowable but am assuming his are the first numbers followed by the allowed. That would make his co high and nox low and hc just within allowable.
there is no o2 or co2 readings in az. it has a brand new full exhaust system. plugs and wires are brand new also set to gap specs. air filter is also clean and its just confuseing the hell out of me. the last emissions run i did was really high nox.
kawazx636
Oct 6, 2021 03:03 PM
Boomer8404
Sep 24, 2015 01:12 PM
94 pickup (OR 2002 3.4l) ???
