EFI Fuse Blows when engaging 4 wheel drive
hey everyone 1990 pickup v6 manual trans, gotta small problem, I took my truck to the hills for the first time yesterday and when I engaged 4 wheel drive my truck died on the spot, thankfully I was close to the camp and got a lift form a nice stranger. came back with my friend and we looked at it and I was getting no spark, I replaced the coil pack and still no go. finally checked the fuses and turned out the EFI fuse (15A) was blown, replaced it and it fired right up, I also should note that 4 wheel was disengaged before putting in the new fuse, drove to camp and then we went out, tried to use 4 wheel again and it went to H4 and was going (thought I don't know if the 4 wheel light came on) and then went to 4 low and bam there went the fuse again. we kept replacing the fuse but it would blow when you cranked the engine, got it back to camp and disengaged 4 wheel and again, replaced fuse and she fires up. drove it all the way home in H2 no problem. also a small note the lights for the air controls had shut off since almost after i bought the truck (feb 2014) but came back on for a while and then off and back on for the ride home. i'm not experienced with wiring at all so any help would be appreciated.
Your 100% sure it was the EFI fuse and not the Engine Fuse??
I don`t have the EWD for 90 so I can look ahead or back .
But if the switch is shorted that turns on the dash light(4x4) it will take out the Engine Fuse on the older style/
On the 92 it will take out the 10amp gauge fuse.
Being the age of the truck who knows what might be hooked to what.
Quite possibly that wire. Check your schematic for color code or physically traces. On the 22RE, when back-up light switch or wiring to it shorts to ground, it takes out Engine fuse.
Might be different on your year-model.
The fuse names on out trucks do not really make sense, and Toyota wiring sucks in that it combines non-essential items (that even when defective will still allow truck to run, like back-up light and turn signals) with essential items (that when broken will prevent truck from running (i.e., ECU, alternator, etc) into one fuse Like the Engine fuse.
Another example is the "Charge" fuse. It does not enable charging, rather, it powers the "charge" error light. The "Engine" fuse enables (excitation) charging.
Like I had always said, back thenmToyota had much better mechanical engineers than electrical engineers.
If it's "slightly" burned, it is slightly bad. Replace it. But also trace it so you'll find the answer to your question why blow the fuse only in 4WD mode.
Related but not exactly same (this is on 22RE) is poor wire management to transmission or transfer case switch...
I also found this open wire (black w/ white stripe) near the fuse box by the battery. I can't really figure from the wiring diagram what it is.
so i took the truck to the shop for an issue unrelated to this but I also told the mech there about it too and he's gonna check it out as well as the oil leak that is going on. i'll have an update when i get more info.
got my truck back and he could not find anything that would cause the truck to blow the fuse, he ran it in 4x4 off and on on the lift for an hour and nothing blew and checks the siring all over, crazy, on a side note that black wire was for my A/C and now it is hooked up and blowing cold air which is nice here in my town since it's hot out here in central California. i drove it in H4 and L4 down my street again after getting it back and it went fine. no clue as to why its ok now.
wow so it did it again, tried running it in H4 and it went, then stopped and shifted into L4 and bam there went the fuse. I but a dollar that something is shorting at the shifter, i'm gonna take off the cover and inspect it this weekend
Pretty easy to tell if the switch is shorted with your Meter.
Unless you have something else piggy backed onto the same circuit.
Or the fuse opening is unrelated and pure chance seems doubtful though.
Does this truck have any electrically controlled lockers that might be wired into this circuit as well .
Wired to engage when ever shifting into 4High or Low ??
they are automatic lockers and are controlled by the selector by the stick. i could not really answer how it works as I have no experience with this truck or wiring in general this is my first yota and I on'y bought it this feburary. I don't have a meter and I don't even know what one looks like or how to use one.
The only way the speakers could effect this is if the stereo is connected to the same circuit as the 4x4 switch.If one of those lockers is on the way out and draws to much current it will open the fuse ??
Being a intermittent problem if it did not happen while at the shop pretty hard to find.
If you were close I would be glad to help.
I would welcome the help if you were near. but the lockers are not electric from what my mech told me, they run off a vacuum, its really weird it sometimes it blows the fuse and sometimes it does not.
update: still haven't found whats causing my problem, i had my truck at a different shop and they didn't know whats up either, they peeled back the o2 wires and found nothing wrong. idk whats going on or how to properly trace wires, i don't if it's related but i am having minor issues with other things like my oil pressure gauge would only work part of the time and my brand new starter wasn't working either all the time, i would need to tap it to get it to work, took it back and autozone tested it and it passed twice, put it back on and it is working now but idk if it will stay that way, feels like this truck is cursed and so am I for winding up with bad vehicles
