ECU Power Supply
Old Aug 27, 2008 | 07:49 PM
colsoncj's Avatar
Anthony... I'd imagine we can all figure it out!! I'd hate for you to have to take it to a shop...
Old Aug 27, 2008 | 07:59 PM
ADH8796's Avatar
Yeah me too but I just want this dang thing fixed and ready to roll. So if that's what it comes down to than that's what I'll do.
Old Aug 27, 2008 | 08:04 PM
colsoncj's Avatar
well, i can understand that... I'd see if Matthew can help, then go from there...
Old Aug 27, 2008 | 08:20 PM
thook's Avatar
Like I said, were I in town...meaning Fayetteville. I'm 20+miles south of you in Winslow, Anthony. But, I am in Fay. on the weekends. Also, I can talk you through whatever on the phone.
265....is that Crossover? I'm real familiar with Fayetteville. So, you live out towards Elkins?
I'm pretty busy during the day taking care of animals, but if you'd like and you're not in that big of a hurry, call me tomorrow at 8pm. I'm done with chores by then. 634-7441
Do you have a testing meter? You'll need to be able to test for voltage.
Old Aug 28, 2008 | 08:58 AM
  #25
abecedarian's Avatar
code 11 (85 or 87) usually means the ECU is not seeing IDL from the TPS sensor when it thinks it should so could be just the adjustment.
considering it's a transplant and there was mention of changing the TPS, I'd be tracing wiring.
Old Aug 28, 2008 | 10:14 AM
  #26
colsoncj's Avatar
Transplant yes, but everything was swapped as one unit, nothing unhooked, motor and wiring harness. Unplugged the ECU, pulled the harness through the firewall, pulled the motor, set it in the new truck ran wiring back through the firewall, plugged in computer, all done. Shouldnt have any wiring problems between the TPS and ECU.
Old Aug 28, 2008 | 10:20 AM
  #27
4Crawler's Avatar
You might want to verify the TPS signals are indeed getting back to the ECU:
- http://www.4crawler.com/4x4/CheapTri...roubleshooting
May have damaged a wire or connector with the swap.
Old Aug 28, 2008 | 03:06 PM
  #28
ADH8796's Avatar
Checked all the wires and everything looks good but the description is right on "Hesitation while accelerating". It's gotten worse though I was able to drive it for a while and now it barely makes it down the road unless I just let it Idel in which case it runs great.
Old Aug 28, 2008 | 05:01 PM
  #29
thook's Avatar
Well, I'm around if you need to call.
Old Aug 29, 2008 | 04:38 AM
  #30
ADH8796's Avatar
Thanks Matthew I'll probably be calling you this weekend.
Old Aug 29, 2008 | 12:49 PM
  #31
thook's Avatar
That's fine, but I'll be at work in Fayetteville. The number there is 582-9185. And, it's fine to call me at work....not a problem. But, if a customer comes in the store we'll have to play phone tag. Cool?
Old Aug 30, 2008 | 07:08 AM
  #32
ADH8796's Avatar
Sounds good man thanks!
Old Sep 2, 2008 | 07:15 PM
  #33
soarerjzz30's Avatar
I was having a similar problem with my 87, I had a similar "hesitation while accelerating". Ended up being the O2 sensor. Had a Bosch sensor and replaced it with a Denso, fixed the problem.
Old Sep 2, 2008 | 07:27 PM
  #34
thook's Avatar
Hey there. Hadn't seen you around here in a while. I see you and your truck every once in a while in Fayetteville. Always looks good, too!
Old Sep 2, 2008 | 07:43 PM
  #35
I like to lay low
Old Sep 18, 2008 | 05:50 PM
  #36
ADH8796's Avatar
FIXED
I pulled the fuel pump and looked at the filter and it was the worst looking thing I had ever seen (looked like clay all over the filter). New filter and I'm golden.
Old Sep 18, 2008 | 07:22 PM
  #37
colsoncj's Avatar
SWEET. Good work man. Glad it was something easy too.
okamikai
Apr 30, 2018 10:19 PM
RatOmeter
Oct 22, 2015 03:17 PM
sanctfy
All Other Toyota Swaps
Sep 15, 2015 02:52 PM
RaginAsian91
Aug 23, 2015 10:27 AM
luckypig44
Jul 19, 2015 11:25 AM
