E Brake dont work???
Old Feb 5, 2013 | 10:56 AM
Paul199's Avatar
On my 1990 4runner my e brake won't work. It's not broken it just needs to be tighten up how would I do this?
Old Feb 5, 2013 | 10:57 AM
BamaYota1's Avatar
Put it in reverse and keep pulling it until your truck stops.
Old Feb 5, 2013 | 11:01 AM
Paul199's Avatar
Ok can you explain how that will help it or fix it?
Old Feb 5, 2013 | 11:05 AM
Philbert's Avatar
Google's a pretty cool site - check it out sometime ;-)
https://www.yotatech.com/forums/f2/r...ustment-44695/
Old Feb 5, 2013 | 11:24 AM
Paul199's Avatar
Awesome I hope this works thanks guys!!! And google what is this google you speak of? Lol
Old Feb 5, 2013 | 12:02 PM
BamaYota1's Avatar
If it doesn't work, you will need to adjust the rears through the access hole below the bleeder valve. Jack the tire off the ground for the wheel you are working on. You'll make the screwdriver turn the adjustment knob until you feel the slightest drag on the drum. Repeat for other side. After you are done, do the emergency brake- reverse trick.
Old Feb 6, 2013 | 08:49 PM
Toymadness's Avatar
i cant post my own threads yet so, i have a 91 toyota pickup and my parking brake light is always on but it works fine. It was parked a few months ago because the clutch was out and when i finally moved it i had to break the brakes free and ever since the light has stayed on but im not leakin break fluid anywhere. any ideas??
Old Feb 7, 2013 | 12:43 AM
Co_94_PU's Avatar
You can create threads just not in the classifieds. There might of been some some maintenance running or something if you tryed else where.. Anyways..
make sure the cap is clean and tight on the res', there is proper fluid levels. Then fiddle with the switch, mine is a little finicky and sometimes I have to bang it into the dash to get it to shut off.
Jun 1, 2021 01:51 PM
bryan34w
Jul 6, 2015 05:53 PM
Jnkml
Jul 6, 2015 01:20 PM
MTLroadierunner
Jul 6, 2015 12:17 PM
Suprarossa
Jul 6, 2015 05:21 AM
