Downside to Arizona vehicles??
I bought my 87 4Runner last year out of Eugene Oregon. Came with a sweet stack of receipts. In going through all of them I find out that it was delivered to and Purchased in Tuscon, AZ, where it lived until 2006.
So there shouldn't be anything bad right? A/C works great, minimal rust, my LPSV doesn't look like barnacles are growing off of it.
But I finally found a downside. The 19 years of Arizona sun killed the defroster grid. Everything looks intact. But after ripping apart my entire tailgate yesterday, following the FSM checking the switch, relay, wiring and the grid, (of course they put it in that order) I rewire everything (broken wires found) cleaned up all the connections AND nothing!
At this point I am frustrated to hell bc I just went through everything and there is no way it could be the window. I have seen pics of other windows on here all rusty and THEIR defrost works. Dangit. So I call the junkyard in Olympia, the guy there has 3 windows, and he'll let me try them out til I found one that worked. I got one that now has voltage moving across the grid so I am hoping it will work, I will findout Friday morning.
I guess if you live in Tuscon, you could gave a rat's behind about rear defrost. But up in Washington a little different story.
I never thought I would figure out a downside to an Arizona raised rig, but thats as close as you will come I think.
Now its almost time to tackle my Cruise control. Back to the Search button!!
But I finally found a downside. The 19 years of Arizona sun killed the defroster grid. Everything looks intact. But after ripping apart my entire tailgate yesterday, following the FSM checking the switch, relay, wiring and the grid, (of course they put it in that order) I rewire everything (broken wires found) cleaned up all the connections AND nothing! At this point I am frustrated to hell bc I just went through everything and there is no way it could be the window. I have seen pics of other windows on here all rusty and THEIR defrost works. Dangit. So I call the junkyard in Olympia, the guy there has 3 windows, and he'll let me try them out til I found one that worked. I got one that now has voltage moving across the grid so I am hoping it will work, I will findout Friday morning.
Thanks. Yeah Black Lake is who I called. David there is a pretty cool guy. He let me take the windows out to the truck to hook em up to test voltage on em. I have been there a bunch of times, but their stock of 4Runners is getting picked clean.
Thats probably where I will end up getting thirds from next summer. (unless Junkers is upgrading then.... Road trip!!)
All Toyota up in Buckley just gets a pricey sometimes, Black lake is fairly cheap.
And talk to A.Wilson013 about the power window relay. He just went there yesterday for the same thing. Either the relays were no good or Alex has something else wrong in his wiring scheme.
And really, a defroster? I just didn't want those guys in the southwest thinking they had all the pristine yotas. It cost me 50 bucks to fix it!!
But looking at the window I got you could tell the difference of the color of the grid. The new one is much shinier and less corroded. Sucks too, overall the old window was in awesome shape.
Its never had tint, and I couldn't see any cuts in it. It just looked corroded, which is weird bc the bottom rails are spotless. Who knows. I just wanted to bring down the Arizonians.
Honestly, I am just jealous of how clean the Arizona rigs are. At least I got one to revel in my own jealousy!!
I've had a lot of experience with 4Runner cruise controls, and the only problem I've ever found with them is the large rubber diaphragm in the under-hood unit gets cracks around the edge, causing a vacuum leak. I've been able to fix every one of them by using black 3M Weatherstrip Adhesive [which stays flexible] around the perimeter of the diaphragm on the vacuum side. It's easy to disassemble the unit and fix it. Scribe marks on the pieces to aid in reassembly. I've never seen a problem with the electronics of the factory cruise control.
