Downey aux gas tank
Old May 2, 2011 | 06:28 AM
coops2k's Avatar
Downey aux gas tank
Does anyone remember the Downey aux fuel tank? It mounted above the spare tire and had a separate filler neck. What I need are some pictures of the tank, the hose connections and the filler neck.
There is company that makes them for about $650.00, but that's a bit more than I can afford right now.
Old May 2, 2011 | 07:46 AM
corax's Avatar
Downey didn't make the tank, it was made by Northwest Metal Products (http://www.nwmp.com/) - Downey resold it under their name.
try here:
https://www.yotatech.com/forums/f77/.../#post50823505
https://www.yotatech.com/forums/f77/.../#post51190568
Old May 2, 2011 | 07:55 PM
coops2k's Avatar
Thanks
Now if I could only find one like you did
Old May 2, 2011 | 08:11 PM
b4wheeler's Avatar
I have one in my 4Runner that I want gone..... Unfortunately shipping would make this impossible or me...
I have thought about using it as a fuel cell for my trail truck....
Old May 4, 2011 | 08:18 AM
coops2k's Avatar
What would you want for the tank?
Shipping should just be a large box and the tank would need to be cleaned of fuel.
Old May 4, 2011 | 10:23 AM
anthony1's Avatar
You can also get another Gas tank from junkyard and make it work. just fab up a mounting bracket.
I moved mine from the original location to where the spare tire used to be. ..
Old May 4, 2011 | 10:39 AM
TylerH's Avatar
Wasnt there a limited edition desert version Sr-5 that had an extra big fuel tank? If you could get a part number for that, that may also be something to think about.
Old May 4, 2011 | 11:19 AM
coops2k's Avatar
any pics of how it is mounted?
So do you have 2 tanks now?
Old May 4, 2011 | 11:52 AM
4Crawler's Avatar
Generally done on the 2nd gens:
- http://www.4x4wire.com/toyota/tech/gas_tank/
I have the NWMP tank in my '85. It works fairly well, but after raising the main gas tank 3", I find the gravity feed no longer works reliably (main tank is now the same height as the aux. tank). So I am working on adding a transfer pump between the tanks. I think the current NWMP tanks have this pump setup, part of the reason the cost went up.
Old May 4, 2011 | 12:18 PM
anthony1's Avatar
yeah, check out Roger's link. I moved the one that was mounted on the side...The D-shaft was kissing it at full flex. I haven't finished it with protection yet... You can use the existing holes and make a bracket to mount to the frame. I have some pics but not the mount. I'll take some pics for you later.
Old May 4, 2011 | 12:38 PM
warpigg's Avatar
why not just buy a generic fuel cell from summit and make that work, there not that expensive at all.
Old May 4, 2011 | 01:06 PM
hilandfrog's Avatar
here's one for $100
http://montana.craigslist.org/pts/2357855132.html
NOT mine, bozo man 2 hrs away from me!
Repo
Old May 5, 2011 | 06:36 AM
xxxtreme22r's Avatar
too bad this one wont fit your ride. https://www.yotatech.com/forums/f109...oducts-234782/ Just popped up.
Old May 5, 2011 | 06:47 AM
wii_tarded's Avatar
I think that's the same one listed in cl
Old May 5, 2011 | 08:21 AM
aviator's Avatar
There was a member here a few yrs back that was making his truck into a custom expedition rig he took a tank from a 70's Jimmy (I think) and mounted it between the frame rails at the back... plumbed it to the main tank with a transfer pump I think...
Had to relocate spare though...
Link may already be quoted above, I don't remember the exact thread title this was about 4-5 yrs ago lol...
Old May 8, 2011 | 05:38 PM
anthony1's Avatar
Here's my stock gas tank mount. Keep inmind that I have a 2" BL so you might have to mane the tank drop down more than mine. I did have issues with the inlet tubes pinching the body so I had to JB well it once. So watch out for that too.
[IMG][/IMG]
[IMG][/IMG]
Old May 8, 2011 | 08:34 PM
coops2k's Avatar
Originally Posted by hilandfrog
here's one for $100
Repo
trying to buy this one, not sure it will work. It's from a 95 4 runner and I have a 87 pickup.
Talked to NWMP and they where going to fax me some stuff, but never did.
Old May 9, 2011 | 06:11 AM
aviator's Avatar
Pretty sure the frames are similar so far as distance between the rails goes, and the spare tire carriers are virtually identical except that the 95 is cable and the 87 is chain. I'd give NWMP a call and ask again just to be sure.
Old May 9, 2011 | 08:06 AM
b4wheeler's Avatar
I sent NWMP an email a long time ago asking for a copy of the install instructions so that I could remove mine without problem.. Again, they never got back to me at all....
Old May 10, 2011 | 05:40 PM
coops2k's Avatar
well, I picked up the one in CL. It looks like it should fit, but I might need to do some mods.
