Doors don't lock when key is turned...
Old Mar 7, 2007 | 06:09 AM
GV27's Avatar
Originally Posted by rdharper
Can't disagree with any of what you've said..... There is enough compute power in any of the cars designed in the last 10 years to produce better logic for all cases. Nothing more than a programming problem. The car has all the sensory information at the computer... in the case you site, the car should shut off any heavy draw when voltage gets to 12.2v where it is at risk of not starting next time you get in. It could post a warning at the dash, in case you needed the lights for some emergency more important than the next start, requiring an override. If you don't take the option, it should shut down, assuming you did not mean to continue the heavy discharge because you were half sober at the bar... for instance.
LOL - actually in that case it was morning and I was hung over!
My wife's Sienna will shut the lights off after a few minutes if you leave them on. My old Subaru wouldn't leave the headlights on with the key off. Which is how it should be - I've never figured out why you would want to have your headlights blasting without the key in the ignition.....it won't let you listen to the dang stereo like that which would be more useful.....but I digress....
Old Mar 7, 2007 | 07:28 AM
Stevo3's Avatar
Originally Posted by GregStevens
Yea, I see what you're saying and I tried that. All combinations of the door/overhead light. Still didn't do it. Interesting attempt though. The light went off when the door closed. I just don't get it...
one more thing to try, the rear door is on its own light swtich aswell, check that switch out. I dont think there is a switch to turn it on/door or off. maybe the bulb burned out in the back, and the switch is bad and you just dont know it.
Just a thought anyways.
Jun 1, 2021 01:51 PM
Johntom240
7
Jul 13, 2015 12:18 AM
razorman8669
Jul 12, 2015 12:13 PM
smiley52
Jul 11, 2015 05:16 AM
AaronM
Jul 8, 2015 07:15 PM
