Does this need to be capped ?????
Old May 15, 2009 | 05:03 PM
swerks's Avatar
Question Does this need to be capped ?????
It seems to be creating a large vac leak. but has been wide open for as long as I can remember
Old May 15, 2009 | 05:11 PM
86Toyrunna's Avatar
ya man, your missing some stuff off of it. theres a plastic screw type thing that goes down in there with a spring so you can adjust it. its a valve. if i had a pic handy id post it.. just look around on here for pics.
Old May 15, 2009 | 05:19 PM
swerks's Avatar
Whats it adjust ?? something with the AC ??? Can I, should I cap it ??? could it be causing my rough Idle ???
Old May 15, 2009 | 05:26 PM
Justinlhc's Avatar
It will definitely be causing some idle issues lol.
I'm not a 22RE owner so I can't say for sure, but I'll guess it's the idle up line for the A/C. Do you have A/C?
Old May 15, 2009 | 05:52 PM
swerks's Avatar
its there but does not work. no belt hooked up to it.
Old May 15, 2009 | 05:57 PM
Justinlhc's Avatar
I would just cap it than. Wrap some tape around it or something if you don't have a cap.
Old May 15, 2009 | 06:09 PM
iamsuperbleeder's Avatar
if I'm not mistaken, it idles up during load from the AC and/or the power steering
Old May 15, 2009 | 06:12 PM
InternetRoadkill's Avatar
It's the idle-up port. There's supposed to be a plastic needle valve screwed into it.
Old May 16, 2009 | 01:48 PM
Keith B.'s Avatar
Both the A/C and P/S use this valve for idle up.
Old May 16, 2009 | 01:56 PM
abecedarian's Avatar
Here's 4Crawler's:
Mine 88 Pic coming soon.
Old May 16, 2009 | 02:21 PM
Old May 16, 2009 | 04:45 PM
swerks's Avatar
should I cap it for now ???? do I need to replace this ???
Old May 18, 2009 | 09:24 AM
swerks's Avatar
I capped it, seems to idle a little better but still not where I would like it. I guess Ill just keep looking !
kawazx636
Oct 6, 2021 03:03 PM
Kamaloha
Oct 16, 2015 05:13 PM
voiddweller
Sep 28, 2015 11:21 PM
charlie_fong
Sep 27, 2015 10:06 PM
