"To do" list while engine is out
Old Jul 25, 2010 | 06:33 AM
scyotapu's Avatar
I finally got around to pulling my engine and tranny out. Found a 2nd 22re that runs and am redoing the timing, alternator, waterpump and various gaskets.
While I have the engine bay open and free, Im looking for things to do to it since I have the space and time. I am already planing on relocating the battery, preparing for a snorkle kit and replacing motor mounts. Is there anything else that I should be looking to do before I put the motor back in? The truck is going to be used as a winter/ offroad truck generally.
Old Jul 25, 2010 | 06:36 AM
waskillywabbit's Avatar
Degrease. Clean. Paint.
Inspect and replace wiring and looms.
Old Jul 26, 2010 | 11:54 AM
scyotapu's Avatar
of course those common task. But is there any other sort of relocating or deletes that are suggested? Ive done some searches and only came up with the battery relocate.
Old Jul 26, 2010 | 02:48 PM
xxxtreme22r's Avatar
front seal and bearing on the trans?
Old Jul 26, 2010 | 02:50 PM
what about the egr and PAIR system delete and using the block off plate from LCE to deal with the water passage behind the head.
Old Jul 26, 2010 | 02:51 PM
yotamonsta-'s Avatar
Rear main seal if you have planed it already??? Wire tuck would be nice looking but alot of work!!!!
Old Jul 27, 2010 | 05:25 AM
scyotapu's Avatar
already have the seal planned. and yea wire tucks are sexy. But this truck is no where near a show truck HAHA.
Havnt heard of this one yet. Ill have to do some research on it. Im really new to the 22re world so im not to familiar with what can and cant be done to these.
Trans is out with the motor, so thats already being tackled.
Old Jul 27, 2010 | 10:50 AM
if your in cali I wouldn't do the egr delete or anything like that though were you would need the emissions stuff.
here is a link to the LCE block off plates: http://www.toyotacatalog.net/M1WebGe...ss=1447&Page=1
Old Jul 27, 2010 | 11:19 AM
scyotapu's Avatar
Nope, In ct. the truck is an 89 so soon enough it will be emissions exempt. Thanks for the link bud.
Old Jul 27, 2010 | 11:22 AM
any questions on removing that stuff, you might wanna ask iamsuperbleeder, as I believe he deleted everything. not 100%sure though. I know he did the PAIR system and that egr crossover though. not sure on oll of the coolant pipes.
I am gonna eventually do mine as well. Since mine is carbed it's a little different. But the carb trucks can get cleaned out quite a bit, especially when running a weber like I am.
Old Jul 27, 2010 | 08:48 PM
scyotapu's Avatar
Are there any performance results from this? And since im deleting EGR and PAIR elements, wouldnt that cause a CEL and then in turn kill efficiency on the motor causing it to run really rich?
Im probably really off since im really into the OBDII scene, and been working on late model toyotas, acuras ,chevys and jeeps.. Thats just what would/could happen on the motors I usually toy with.
Old Jul 28, 2010 | 04:44 AM
not sure on the egr thing as I believe some of the 22re's I believe have a sensor and some do not. Might want to search on here with that one as it has been done many times on here. as for the pair system, nothing should be monitoring that at all.
Old Jul 28, 2010 | 05:53 PM
scyotapu's Avatar
Yep, I found a few threads on it. Havnt come across a DIY yet. Maybe if I do it sucessfully Ill write one up and put it up here, kinda like a new members way of participating.
Im kinda torn on it though now. Ive seen some people say the motor performs better, same and worse.
Old Jul 28, 2010 | 08:13 PM
Matt16's Avatar
Definitely your rear seal. Sucks having the rear seal go. Huge labour for such cheap simple, tiny part.
Old Sep 6, 2010 | 04:49 AM
scyotapu's Avatar
Sorry to bump my thread, but upon further inspection of the motor I picked up i found its been rebuilt. New seals, new timing, new valvetrain. Havnt looked at the pistons but it has pefect compression! A damn steal for the price I paid for it. Going ahead and attacking the EGR/PAIR system today. thanks for your advice guys!
nanhodges2733
May 29, 2020 03:28 PM
jasonty
41
Dec 23, 2018 01:00 PM
mskalmus
May 28, 2017 07:51 AM
hexrain
Jul 12, 2015 01:13 PM
toyoda8488
Jul 5, 2015 10:18 PM
