distributor help!!
Old Feb 9, 2014 | 06:57 PM
abatter24's Avatar
distributor help!!
i have an 88 toyota pickup with a 22re and i need to know the air gap for my truck please help! i cleaned the distributor cause it had corrosion and took that magnetic thing out to clean it and now i need to know the correct gap and how to gap it. i also made sure it was 5 degrees BTDC. please help! thanks!!
Old Feb 9, 2014 | 09:50 PM
Gevo's Avatar
Search yotatech for fsm. Its pretty straight forward in the service manual.
Old Feb 10, 2014 | 04:52 AM
abatter24's Avatar
Will it be in a Haynes service manual
Old Feb 10, 2014 | 05:38 AM
Gevo's Avatar
I don't know if it's in the haynes, but you should be able to find the fsm online.
I'll let someone else chime in here with the link, as I have a 1991 and the link I use is http://personal.utulsa.edu/~nathan-buchanan/93fsm/
If this one also covers your year (I do't think so, I think it starts from 89) good, otherwise, try this link --> http://daemon4x4.org/portal/downloads.php?dcid=17 it has several fsm's, find the one that says 4runner/hilux for 1988.
Old Feb 10, 2014 | 03:35 PM
abatter24's Avatar
i cant find it cause those websites aint working but all its doin is when i try to start it it backfires real loud but never actually starts
Old Feb 10, 2014 | 04:13 PM
Gevo's Avatar
To be honest there can be many reasons for your problem. Have you checked timing? Start from there.
Old Feb 10, 2014 | 04:45 PM
abatter24's Avatar
I Fixed it the timing was off 180 degrees so it runs perfect now I have all the power from the engine that I should have because it was sluggish to begin with but now it runs good thanks for the advice!
Old Feb 10, 2014 | 05:16 PM
Gevo's Avatar
Good. You got off easy!
Old Feb 10, 2014 | 05:37 PM
abatter24's Avatar
Haha ya thankfully
JonG85
Jan 18, 2023 04:31 PM
LittleUgly
15
Jan 2, 2020 01:30 PM
Sam hain
19
Sep 30, 2015 08:25 AM
EatChipsNow
Sep 9, 2015 01:25 AM
seab1209
Sep 3, 2015 05:41 PM
