Dimmer switch
Old Dec 10, 2015 | 05:28 PM
nwPaYota's Avatar
Dimmer switch
I bought a gauge cluster and it says for the lights on it to hook it up to the dimmer switch for your gauges. Which wire do you splice into the red or white?
Old Dec 10, 2015 | 06:21 PM
RAD4Runner's Avatar
An Escalade?
Old Dec 10, 2015 | 06:23 PM
nwPaYota's Avatar
What? The gauge thing I bought has water temp, voltage, and oil pressure but to hook the lights up for the gauge I want to splice it in with the dimmer switch. There's a red and white wire and I don't no which one to splice into.
Old Dec 10, 2015 | 06:51 PM
RAD4Runner's Avatar
Originally Posted by nwPaYota
What?
(LOL! Sorry, could not help it... A problem well-stated is a problem half-solved.)
What truck-year-model?
On your (after-market, right?) gauge cluster, how many wires are there that need to be hooked up to stock wiring?
Why don't u post schematic of your tail light curcuit and of your gauge cluster so people who understand electrical can help you? Remember... some of us may be on the other side of the world; how do we know what u have in front of you?
Old Dec 10, 2015 | 09:46 PM
Terrys87's Avatar
For the 84-95 the cluster is a direct swap and no need to splice in for the dimmer switch.
Old Dec 11, 2015 | 05:31 AM
scope103's Avatar
If you bought an AFTER MARKET gauge cluster (I think Terrys87 is referring to a stock Combination meter, usually called a "cluster"), the dimmer switch on a 1993 4Runner has a W-B to ground, and a W-G to attach to the GROUND side of the combination meter lighting.
So, I don't think any of us know what vehicle you're talking about, what "cluster" you're talking about, what dimmer or what wires.
Old Dec 11, 2015 | 11:49 AM
wyoming9's Avatar
Red face
Perhaps the OP means the High low switch?/
Instead of the Rheostat??
Old Dec 11, 2015 | 12:56 PM
RAD4Runner's Avatar
... There's a red and white wire and I don't no which one to splice into...
Where's the red and white wire- on your AFTERMARKET gauge cluster or the stock wiring?
Dustin Egle
Mar 4, 2016 09:47 AM
Brock Lee
Dec 24, 2015 12:01 AM
Malcolm99
Dec 14, 2015 08:44 PM
keganthewhale
Dec 11, 2015 02:23 AM
Bajawfo
Dec 6, 2015 09:42 AM
