Different Steering Stabalizer mounts?
Hi guys,
I was about to replace the steering damper/stabalizer on my '93 4runner (22re) but ran into a hiccup.
One of the mounts on the new damper is different.. the one on there now has a joint that looks like a tie rod end joint where it can swivel around. (on a side note, what is that kind of joint called?). The one I'm about mount is just attached with a regular nut and bolt.
here's the replacement I got: Monroe SC2947 Magnum Steering Damper : Amazon.com : Automotive
Here's what the one looks like that's on there now (mount wise): Steering Damper Toyota 4Runner RN130 YN130 VZN130 4WD | eBay
This article seems to imply that it's ok: http://www.4crawler.com/4x4/CheapTri...ringStabilizer
What say you guys?
Thanks!
What say you guys?
Thanks!
ball and socket joint.
The one I put on my truck looked like your replacement. It has worked just fine. I would say it is not really a "regular nut and bolt" since it is mounted through fairly thick rubber and has the taper on one side. That seems to allow enough give that the ball and socket joint is not necessary.
Yeah, I got in installed yesterday, but then I had some issues replacing an upper ball joint. the long story short is one of the top bolts sheared off when I was torquing it down, then I did something stupid with the replacement and now I need a replacement for my replacement. =)
I basically replaced the front suspension and steering system (pitman arm, TREs, ball joints and shocks), so i'm hoping to get a nice ride!
That happens sometimes. Let us know how it turns out in the end. I considered replacing all of my balljoints, bushings, tie rod ends, etc when I got my truck last year, but somehow that has never floated to the top of the priority list. Hopefully I'll get a chance this summer to bounce off enough rocks that those parts become a priority
First I'm putting in a lunchbox locker in the front and an LSD in the back. Should be good to go for awhile after those projects!
I finally got everything put back together and took her around the block for a test spin.. feels MUCH tighter and stable!
Unfortunately, I'll have to wait till tuesday to get the alignment done and new tires. Can't wait to get her on the freeway and see how she does there!
Jcrawl94
10
Oct 24, 2015 04:34 PM
WTB[PacNorWest]: All Power steering parts '79-'85
zombie_stomp
Aug 17, 2015 05:29 PM
terminator
Jul 27, 2015 07:13 PM
jon.r
Jul 11, 2015 03:34 PM
