different overheating problem
Old May 13, 2006 | 08:48 PM
NC-B17A's Avatar
I have 240,000+ mile on my 90 4runner & in traffic with the A/C on no problem I can hillclimb with the A/C on & still no problems but the min I get to 65-70 & hold that speed it starts heating up I can turn on the rear heat & it helps alittle. I did a flush & a new 180 thermostat it runs cooler at lower speeds.
I'm prob going to get a new radiator but wanted to see if anyone had a other ideas.
Old May 13, 2006 | 10:06 PM
marko3xl3's Avatar
Fan clutch?
Old May 13, 2006 | 11:01 PM
NC-B17A's Avatar
fan seems fine it has no play in it.
Old May 16, 2006 | 06:19 PM
NC-B17A's Avatar
on cool days & most nights it runs cool
Old May 16, 2006 | 06:24 PM
ChickenLover's Avatar
I'd have the radiator professionaly cleaned. I had mine rodded and rebuilt (top end) for about $85 last year. Good as new.
Old May 16, 2006 | 06:25 PM
waskillywabbit's Avatar
Perhaps a bad t-stat...clogged heater lines...got any leaks? I'd say it is something other than the radiator...unless it is clogged...but you'd think a flush would clean it out.
Old May 17, 2006 | 10:16 AM
NC-B17A's Avatar
I already changed the t-stat no i don't have any leaks. my heat works great lol
Old May 19, 2006 | 07:21 PM
daveyboy's Avatar
Did you ever figure out what the problem was? Mine just started doing the same thing,,,its a 93 v6
Old May 19, 2006 | 08:32 PM
NC-B17A's Avatar
Not yet I am going to try to test the radiator & the hoses this week end
Old May 20, 2006 | 09:03 AM
daveyboy's Avatar
Ok, well let us know what it is,,,,I figured i would pull the radiator and have it rodded. Thats what the problem is I bet. But f just doing a flush works ,,,then I would rather go that route
Old May 20, 2006 | 10:13 AM
StoogeBrother's Avatar
check aux cooling fan
Hey dude, dont forget to check the operation of your aux cooling fan, operated by thermo switch... sounds like the prob may be happening during a/c poeration.
Old May 20, 2006 | 10:39 AM
Yoda's Avatar
To me it sounds like a radiator problem. At highway speeds, the "ram air" does most of the airflow through the radiator. Does your aux fan function with the A/C on? Radiator isn't packed with mud?
Old May 20, 2006 | 02:02 PM
NC-B17A's Avatar
the radiator is clean ( as far as air flow) & the aux fan works
Old May 22, 2006 | 09:52 PM
w3s's Avatar
w3s
I had the same problem. I took the radiator to a shop close by to check the flow and they told me that it was fine. They tested it by filling it with a garden hose and if it didnt back up then it had a good flow. That made since to me at the time so I ended up pulling my tarus fan, buying a new shroud and after market fan clutch just to have the same problem.
I ended up going to another shop and the guy showed me just how bad the radiator was when he was rodding it....I ended up getting a new radiator and things have been fine ever since....
Old May 31, 2006 | 12:15 AM
NC-B17A's Avatar
I installed a new radiator last night along with a Taurus fan. It idled for almost 20 mins with the air on & no problems. I hit the interstate & had no heating problems. But it was night so I will see later on today.
I was suprised to find a good bit of crap on the front of the radiator blocking airflow.
Old May 31, 2006 | 07:45 PM
NC-B17A's Avatar
Ok that was it. The new Radiator fixed it. So daveyboy if yours is doing the same thing then there is a good chance its your radiator or its blocked
the1998sr5
15
Jul 14, 2020 08:35 PM
the1998sr5
27
Nov 17, 2015 09:30 AM
Logz808
Jul 26, 2015 07:09 AM
the1998sr5
Jul 16, 2015 06:20 AM
Avenged
Jul 9, 2015 07:55 AM
