Difference between valve tick and timing chain???
Old Aug 7, 2014 | 04:26 AM
AdmiralYoda's Avatar
This is newbish of me but here goes. My 87 4Runnah w/22RE has just been woken from a 14 year nap and some maintenance issues are popping up.
When the engine is hot I hear a valve tick at idle. Fine, they need to be adjusted. But I'm wondering what a timing chain bouncing around sounds like. When I rev the motor in neutral I hear a distinct ticking/clanking sound when the revs are coming back down, specifically in the lower RPM's.
The motor is out of an 85 and I am not sure of the mileage but I think its around 100k. I know I can just take the valve cover off and look but I'm wondering if someone can help describe the symptoms and sounds of a timing chain that's going.
Old Aug 7, 2014 | 09:00 AM
wyoming9's Avatar
Red face
Well if you really want to know pull the valve cover.
Get a good flash light and check things out looking at your timing chain guides.
Then figure out what you need to do.
Old Aug 7, 2014 | 09:05 AM
Well I already knew that answer!
Since I've never experienced a timing chain problem before, I was wondering if there was a distinct sound that is obvious once you hear it.
My tick isn't bad enough to make me want to adjust the lifters ASAP...it will be a project for over the winter when I have more time. Its the tick/rattle when the RPM's come down after revving that is a new sound for me.
Old Aug 7, 2014 | 11:43 AM
Rerunn's Avatar
Exhaust leak maybe?? Just an idea
Jun 1, 2021 01:51 PM
Ichneumon
Sep 27, 2015 04:21 PM
Jnkml
Jul 6, 2015 01:20 PM
Vargntucson
Jul 4, 2015 12:15 PM
