difference in 88 to 93 3vz?
Old Sep 12, 2008 | 08:46 PM
shancerlelby's Avatar
lol rediculous . thanks for the info deathcougar! well i guess im holding off on buying an 88 3.0 for 400 bucks. damnit. anyone have a 3.0 for sale near central b.c.? jay? im having no luck here unless i want to swap to a 22re or buy a 1200 long block from the autowreckers.
Old Sep 12, 2008 | 08:52 PM
Kiroshu's Avatar
I do know that the old 3.0s are a bit more chattery than the new ones. Also the throttle bodys a tad different if you look at a 94 3.0 and an 88 or 89 one.
Old Sep 12, 2008 | 09:39 PM
snap-on's Avatar
low ohm vs high ohm injectors.
water distribution block is different on the back, but that also has to do with what options you have.
motor mounts are different
disturber caps are different
timing belt tensioners and therefore fan pulley bracket.
some do and dont have oil coolers on the side.
Old Jan 10, 2009 | 06:54 PM
yota954runner's Avatar
how far off is the mounting of the motor mounts??
Old Jan 11, 2009 | 05:45 PM
  #25
anyone else have any imput on this difference between the 88 3vz or the 95 3vz-e???
i just bought a 88 model motor and really need to know for sure before i even start trying to swap the motor in my 95 if it will strait bolt up or not.
has anyone put a 88 model in their other year model truck/4runner?
Old Jan 11, 2009 | 05:47 PM
  #26
DeathCougar's Avatar
You will have to drill and tap the block to get it to fit. The motor mounts are 88 only.
See post #6 for why you cannot put an 88 engine in your 95.
Old Jan 14, 2009 | 05:56 PM
  #27
thanks for the reply DeathCougar, thats all i was really lookin for. i read the whole thread before and seen what the differences were but i just was looking for you or someone else to reply with the same facts. I'm thinkin im going to just try to sell the motor, seems like too much of a headache for something that could have been just a direct replacement. wish i woulda seen this thread before buying the motor.
Old Jan 14, 2009 | 06:04 PM
  #28
ozziesironmanoffroad's Avatar
and supposedly the older 3.0s dont blow head gaskets as much as the newer ones... namely 91-93 that blow them.... am i right or way out of left field?
Old Jan 14, 2009 | 07:09 PM
  #29
bigtrucknwheels's Avatar
mid 1990 model year production, they quit using the asbestos head gaskets. the mid 90 trucks and older are quite a bit more reliable. I have two, both with their factory head gaskets, that have 215k miles on, but yet the failed head gasket used later on would blow sometimes before the 100k mark.
as far as which v6's were more prone to failure after mid 1990, I am not sure haha.
Old Jan 14, 2009 | 07:21 PM
  #30
Kiroshu's Avatar
Not entirely true i had an 88 4runner v6 and it blew a head gasket ay 289,000 Miles, which is wow but yea they do blow em.
Old Jan 15, 2009 | 01:16 PM
  #31
some good info guys. well if anyone wants an 88 model 3vz i got one for sale.
Daenerysdad
Oct 1, 2015 07:33 PM
EatChipsNow
Sep 9, 2015 01:25 AM
viesail
Sep 5, 2015 04:23 AM
pplusent
Sep 2, 2015 11:56 PM
