diff diff stud questions
Old Jul 13, 2008 | 10:12 AM
bigt's Avatar
ok so i snapped one of th studs putting my welded rear in a few months back...just filled it up when ever i went on a trail run...
fastforward to today..
take my whole rear end apart today go to start installing my m8 1.25*40 grade 8 bolts to replace studs and they are really tight to screw in and i think too long...
now should i use these...
or wait till tommorow and get some 30s?? or wait till tommorow and order 10 new toyota studs???
Old Jul 13, 2008 | 10:19 AM
Matt16's Avatar
Get the right ones, taking out or installing a third with studs that are too long will be a pain, the top of the third will catch on the swaybar. Get the Toyota ones.
Old Jul 13, 2008 | 10:22 AM
dirtoyboy's Avatar
well how long are your studs?
Old Jul 13, 2008 | 10:24 AM
bigt's Avatar
i was only using 40mm bolts i get some 30s too or order studs tomorrow i guess.. i dont have a sway bar on the truck.
do you know which ones are 30s and which ones are 40s on the diff?? i already took all the studs and 3rd out
Old Jul 13, 2008 | 11:14 AM
BLKNBLU's Avatar
I put these in the SFA I'm building
http://www.trail-gear.com/tech/diff-...iff-studs.html
and was having a hard time getting them to thread. I also didn't have enough clearance to get the allen wrench on them from the inside. After struggling like crazy with the first one, I realized I hadn't cleaned the threads with a tap. After cleaning, they went in with fingers and only needed the allen to do the final tightening. By the time my fingers were finished, the allen would clear and all was well. So consider that if you haven't already.
Old Jul 13, 2008 | 11:32 AM
bigt's Avatar
THANKS MAN thats my issue they thread fnoe for a bit then are too greasy to turn by hand!!!
ill get some 30s andtry and find out which ones go where.... they should work better than studs..they are the same ones as trailgear sells pretty much...
o well maybe the studs from toyota are cheap ill try that route too... my carpotunnel has crippled my hand for the rest of the day now anyways
thanks
Old Jul 13, 2008 | 01:08 PM
Matt16's Avatar
thanks
You know about the double-nut technique for tightening studs right?
Old Jul 13, 2008 | 01:58 PM
bigt's Avatar
yes i do.. thats why i kinda want to go buy new toyota studs..
but alot of poeple say these grade 8 allen bolts are the way to go...
ny current studs the nuts are seized on and 1 is broke...
Old Jul 14, 2008 | 05:53 AM
Crawdad's Avatar
The studs suck, the button head allen bolts are the way to go. DEFINITELY grab a tap and chase the threads, though.
tj884Rdlx
Aug 28, 2015 12:04 PM
makemusic116
Aug 2, 2015 05:23 PM
makemusic116
Aug 2, 2015 04:40 AM
Steven.m.paulk
Jul 24, 2015 01:44 PM
scottyg486
Jul 19, 2015 05:34 PM
