Dash lights dont work
Old May 21, 2006 | 02:21 PM
zombi's Avatar
I recently installed a CD player in my 90 4runner 22RE 5 speed, now my dash lights do not work. I used a wiring harness. I pulled the dash apart looking for the culprit but no luck. I even reinstalled the old tape deck and still nothing. All the fuses are good. Anyone have this problem?
Old May 21, 2006 | 04:43 PM
Elton's Avatar
i had the same problem its was the ground for the stereo turns out the ground in there stock radio harness wasint the best so i rewired and new ground and now i have guage lights..... if it anit that then a wire must be shorted out some where
Old May 21, 2006 | 04:49 PM
Yota Runner's Avatar
Have you checked the dimmer nob on the left side under the vent area? I once thaught my lights didn't work but I found that someone had turned it off thinking it was the switch to my fog lights. Sove times the best place to start is the easiest problem to fix Just an idea.
Old May 21, 2006 | 04:51 PM
zombi's Avatar
Elton, Thanks for the reply. Thats one thing I didn't think of. Mabey it needs a common & floating ground. I am going to try re-grounding it right now. Thanks man I really appreciate it. It really sucks bad having no dash lights (My eyes are always looking at the oil pressure gauge). I'll let you know if I git r fixed.
Old May 21, 2006 | 04:57 PM
Elton's Avatar
no problem on my 93 pickup i had to ground it but my 91 4runner i didint i guess the 4runner had better wireing
zombi's Avatar
Yota Runner, Yes that was the first thing I checked. I'm just like you, start at the easiest thing it could be no matter how obvious it may seem. I checked the dimmer, all fuses, relays connections, hooking up the old radio. Nothing worked. Elton gave me a good point of view to check out, the damn ground. I hope thats it. Thanks for everyones replies, I'm off to fix my lights. I will post what I find out.
Thanks Guys.
Old May 21, 2006 | 05:38 PM
zombi's Avatar
Well, the ground is good. I ran a jumper wire to the neg battery terminal, no luck.
Any other suggestions?
Thanks
Old May 21, 2006 | 05:45 PM
Elton's Avatar
umm i dont think it would work like that i ran a ground wire from the cd player to the stereo holder frame
Old May 21, 2006 | 07:58 PM
zombi's Avatar
I tried that first.
Jun 1, 2021 01:51 PM
colinmil
Jul 6, 2015 04:03 PM
Steezy96yota
Jul 6, 2015 10:00 AM
HRDC0R19
Jul 5, 2015 06:43 PM
Valvoman
Jun 28, 2015 02:45 PM
