Dash Brake/Alt Light
'88 Brake & Alternator Dash Light came on today. Is the battery shorting or the alternator going south?? If disconnect battery and engines continues to run it's the battery if engine dies it's the alternator? Thanks in advance
Possiblity that either one or both the alternator or battery are dying. Either one faulty can cause failure in the other. Take 'em both off and then down to the local chain auto parts store (Autozone, etc.) and have them both load tested. Then go from there.
Mike in AR
Mike in AR
I would guess alternator, as an alternator can carry a dead battery. Unless you were at idle.
Based on your experiment yes, thats correct. Howver I wouldn't suggest taking the battery away from the alternator with the engine running, they dont like that.
alternator
this is the warning that it is going out (brushes are worn)
find the local rebuilder and have him fix you up
go to roger browns site and he has the kits to do it yourself
just dont trade your original parts in for a rebuilt one (NAPA, Checkers, etc)
they are usually junk
ashersullivan88yota
Jan 18, 2022 05:37 PM
FS[PacNorWest]: Toyota Inclinometer/Altimeter
AkitaDog
Sep 1, 2015 08:05 AM
Johntom240
7
Jul 13, 2015 12:18 AM
