CV Boot replacement - Toyota or not?
Old Aug 17, 2010 | 07:05 AM
alfio's Avatar
hello all
i've got a bad passenger's side outer CV boot on my '92 and i'm reading up on yotatech as to how to do the repair in the most efficient yota-techy way.
anyhow, it seems straighforward enough but there is one part i can't quite figure out. because my axles are fine at the moment, my idea was to go to the stealership and get a boot kit ($40) and go about that way, keeping everything OEM as is usually my preference.
for the hell of it though, i called a couple of aftermarket places (napa, auto zone, etc.) and for a little more than what the stealership wants, i can get a rebuilt axle with a lifetime warranty ($60).
am i nuts for wanting to keep it all toyota? or does it make sense to go with the parts store rebuilds with lifetime warranty on this? appreciate comments on the wisdom of either option.
Old Aug 17, 2010 | 07:17 AM
fdp101452's Avatar
I went with oem boot kits when I did my truck. My joints and axles were fine, just cracked boot on one side. However, if I had needed axles, I would have went aftermarket......regards......Rick
Old Aug 17, 2010 | 07:34 AM
scuba's Avatar
Aftermarket CV's suck. If its just a blown boot, reboot your OE axle.
Old Aug 17, 2010 | 09:04 AM
RustBucket's Avatar
The CV boot kits from the autoparts store ($10) are probable fine anyway.
Old Aug 17, 2010 | 12:34 PM
tim a.'s Avatar
I just ordered 4 boots from rock auto for 40 somethin bucks.Supposed to be high quality
Old Aug 17, 2010 | 12:57 PM
Ardent's Avatar
My NAPA remans went out within about a week's worth of driving with the hubs locked... I'm glad I never gave them my OEMs.
Old Aug 17, 2010 | 07:18 PM
pruney81's Avatar
I've had a bad experience with the lifetime CV's from Autozone as well. They started clicking about a few weeks after I put them in.
If I ever have to replace a CV again, I'd probably get a used Toyota unit before aftermarket
Old Aug 18, 2010 | 06:33 AM
vasinvictor's Avatar
Got 2 cheap "lifetime warranty" shafts from AutoZone cheaper than 2 boot kits from Toyota. They've been working great and they're not too bad to change once you've done it a time or two. Hope they aren't as bad as everyone says... Just FYI, jack up the control arm til the bumpstop is nearly touching and you won't have to remove ball joints. You will have to unbolt the bottom of the shock but then the shaft has just enough room to wiggle out.
Old Aug 18, 2010 | 11:57 AM
Outsane's Avatar
keep your boots oiled.. and they will crack less often...
Just smear some grease on them every now and then to keep the rubber from drying out..
Niameyrider
Jun 25, 2015 05:50 AM
stretch786
Aug 3, 2005 02:17 PM
HBoss
Dec 20, 2004 08:45 AM
peterbilt
11
Jun 19, 2002 10:56 AM
