CV Axles question
Old Dec 18, 2005 | 03:32 PM
shmily524's Avatar
CV Axles question
I recently finished replacing the CV axles on my 90 4runner (3.slow, 4x4).
When I was putting everything back together on the driver's side, there was only room for the snap ring and not the spacer. The snapring I am talking about is the one that holds the axle from sliding back into the steering knuckle. Also, on the engine side of the steering knuckle, the cv axle does not want to stay seated against the oil seal on the knuckle. I can push it up against it, but it just pushes back out so there is a gap of about 1/2" there.
There is nothing that I can see blocking it.
Any ideas? :pat:
Old Dec 24, 2005 | 03:11 PM
jrfast's Avatar
post some pictures that describe what your saying
Old Dec 24, 2005 | 03:21 PM
Flamedx4's Avatar
If I understand, you are talking about the same side, right? The side where you couldn't get the washer in is the same side that won't stay tight against the dust seal?
First, here's a tip for pulling the axle tight so you can get the washer and snap ring in place. Put the bolt in the end a few turns and hook it with a claw hammer. You can then easily pull on it.
Second, I suspect that your snap ring came undone. That's the only thing that would allow the axle to back out enough that the dust ring won't seal. When you get the washer and the ring back in place, the dust ring should stay sealed.
Don't drive it this way! Fix it right away.
Old Dec 24, 2005 | 04:37 PM
Tofer's Avatar
Sponsor
this has happend to me a couple time (i;ve replaced the CVs 6 times in a year and a half) use the gold safty washer/bolt and a claw hammer or small crow bar to pull the CV it will go, i promise. you have to get the rubber grease seal to go into place. failure to get it to set will result in water getting inside your spinle shaft and ruining the wheel bearing.
Old Dec 24, 2005 | 07:05 PM
shmily524's Avatar
Thanks guys!
I used a claw hammer and was able to pull it out enough to seat the snapring.
Next: install HD springs in the back...
Old Dec 24, 2005 | 07:06 PM
Tofer's Avatar
Sponsor
did you buy them yet? i have a set i'll sell you.
Old Dec 24, 2005 | 09:09 PM
shmily524's Avatar
Not yet... Are yours new?
Old Dec 24, 2005 | 09:28 PM
Tofer's Avatar
Sponsor
no they are used. i bought them used from someone on this site, used them for a year and then went to Land Crusier Coils.
oldirtydirt
Feb 23, 2020 09:30 AM
polo451
13
Nov 20, 2016 07:49 PM
jerusry
Oct 19, 2015 05:28 PM
delmert
Sep 30, 2015 04:34 PM
deepmarsh
Aug 6, 2015 03:44 AM
