CT Emissions issues
Old May 15, 2012 | 09:33 AM
92 flatbed's Avatar
Angry CT Emissions issues
About a month ago, I went to emissions for bi-annual test, and Failed. Unburned hydrocarbons were 190PPM, allowed 160PPM.The Monoxide and Nitrogen sulfide were both extremely low (CO read .62%, allowed 4.47%, NOx read 1081PPM, allowed 5793PPM.)
I changed plugs ( Denzo TT's) And put in a new O2 sensor (also Denzo) Wires, cap and rotor had been changed last summer, so I figure they are good. Truck ran noticeably better.
I went back for the retest, it failed , with about the same numbers.
I then retarded the timing, to 0* BTC, cleaned the K&N filter and changed oil/filter.
Retested again, about same numbers...... (187 PPM hydrocarbons)
Any Ideas?
Old May 15, 2012 | 10:53 AM
Terrys87's Avatar
Sounds like you need to talk to ChefYota4x4.. He just passed his and has been thru quite a bit with his. He has a thread on here about it. Alot of good info on it and what all he went thru. He is very helpful.
Old May 15, 2012 | 11:33 AM
92 flatbed's Avatar
I read through that thread, he actually had a different emissions issue.... He was High on NOx.... Not Hydrocarbons.
Old May 15, 2012 | 09:42 PM
scope103's Avatar
I've never owned a vehicle in CT, but I think need to look at your numbers again. CO max should be around .5-1%, and NOx max around 500-1000ppm (NOx is oxides of nitrogen; no sulfides are tested). http://www.autoshop101.com/
But your problem is HC, and your numbers sound correct. The most common cause is ignition misfire (every time a plug misses, all that unburned gas goes out the tailpipe.) The link above (follow to OBD-1, Emission Analysis) gives a whole stack of other possible causes.
Since you're relatively close, I'd also check the operation of the O2 sensor. You don't even need to get under the truck. http://www.ncttora.com/fsm/1990-1995...e/heatedox.pdf (You'll need either a digital voltmeter with an "analog bar" to see the 6-times-in-10-seconds change, or an old-fashioned needle meter. Alas, most cheap needle meters don't have a low enough scale.)
Old May 18, 2012 | 09:09 AM
92 flatbed's Avatar
When putting Timing back to normal, I re-checked for vacuum leaks, and found one at the Cruise control vacuum motor. after fixing that, with timing at normal setting, It passed at 160 PPM hydrocarbons.
82yodahickman
34
May 16, 2017 01:00 PM
montanatruck
Feb 26, 2017 07:07 AM
yipyip45
Dec 2, 2015 08:16 PM
tj884Rdlx
Aug 28, 2015 12:04 PM
