cruise control flashing/ high idle???
Old Nov 20, 2009 | 05:00 PM
Trauma901's Avatar
Got a 95 4runner, 3VZE automatic 2wd. Until today, cruise control worked fine. Now, when I attempt to set it, the cruise light just blinks and won't. Any ideas?
Also, the engine idles about 1250 in park or neutral, which seems a bit high to me.
Thanks for any input
Doug
Old Nov 22, 2009 | 01:21 PM
Trauma901's Avatar
Btt btt
Old Nov 22, 2009 | 04:07 PM
stormin94's Avatar
Mine does that from time to time, maybe once or twice a year. I just hit the steering wheel, and that usually fixes it. I have no idea what causes it though.
Old Nov 22, 2009 | 10:42 PM
JeEVeS's Avatar
I have the same thing happen. When it does blink i can't use cruise until i turn the truck back on. First time my CEL went on so i figured it was that. But not sure. Bad connection some where (hitting the wheel) could be the cause.
I had another long shot thought of maybe driving conditions. I know in some other vehicles you can not engage cruise in bad conditions such as snow (temp regulated). However this was on a much newer more expensive suv.
When my buddies 3vze idled high it was a mess of egr problems. On my 22re it was a simple throttle adjustment.
Is your check engine light on?
Old Nov 23, 2009 | 07:49 AM
Trauma901's Avatar
Hit the steering wheel! Check!!!
Nope, no CEL.
Old Nov 23, 2009 | 12:54 PM
Lt. Dan's Avatar
When our speedometer cable was going out, (95 Runner, 3.0) the speedometer needle would wobble.
That would kick off the cruise control and make the cruise light blink.
After I replaced the cable, (Ugh, nightmare!) it worked fine.
My $.02,
Old Nov 23, 2009 | 09:08 PM
stormin94's Avatar
Nope, no CEL.
Did it work?
Old Nov 28, 2009 | 07:20 PM
Trauma901's Avatar
Okay, so, suprisingly, hitting the steering wheel worked. Sometimes its the simple things.
Anyway, just got done with the SeaFoam treatment, seems to have helped tremendously, idle is a bit better, still higher than I'd like, but better.
Charecter1
Nov 6, 2023 10:08 AM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
jake_v
Jul 22, 2015 03:17 PM
kyletbert
Jul 17, 2015 11:39 AM
sojourner567
Jul 16, 2015 08:52 PM
