Crank Pulley Faceplate Bolts
Old Mar 6, 2023 | 04:36 PM
MooseRunner's Avatar
Howdy,
Putting a 3VZE back together after water pump, timing belt, tensioner, pulleys, etc job. Unfortunately I broke a bolt from my pulley holder off in the crank pulley. I was unable to get extractors or left handed bits to bite and stopped short of stripping threads.
Can the crank pulley be re installed with just three of those four faceplate bolts torqued properly? Not sure if this may throw something off balance or out of alignment.
Thanks!
Old Mar 7, 2023 | 08:19 AM
mechkw's Avatar
Probably, but why not pull the balancer off and get from the back side and do it correctly. I've seen them come into the shop that way without seeing any issues
Old Mar 7, 2023 | 09:42 AM
JoeS's Avatar
Agree with mechkw. You have every thing off now, so removing the balance and properly removing the sheered off bolt make sense. Easy to work with it off for what ever method you plan. Gives you peace of mind there will not be a problem down the road with just 3 bolts.
Old Mar 7, 2023 | 10:11 AM
Thanks for the replies so far. I tried to but the pulley i have has a solid backing theres no holes on the other side so i couldn't access them.
Im not sure if that pulley is OEM or if i have an aftermarket style, this rig is a 1993 so its the later half of the 3vze. Id like to use it as theres no condition or function concerns with it. A new one is around the $100 mark which is fine but id like to use the one in front of me. Im almost bottomed out and i cant get any extractors to bite enough to spin it out. Heat wont work snd manually turning extractors by hand and wrench still no luck.
Old Mar 7, 2023 | 04:15 PM
Jimkola's Avatar
YT Community Team
5 Year Member
I've used a Dremel to cut a groove in broken bolts so I could use a screwdriver.
Old Mar 7, 2023 | 06:24 PM
Would be too small unfortunatley for these. It appears the thread size for m8x1.25. Im going to drill it out and re tap the thread. Im out of bolt material to work with.
Old Mar 8, 2023 | 06:53 AM
Jimkola's Avatar
YT Community Team
5 Year Member
Cool. I'm glad you're fixing it.
If I had a 6-lug wheel and one lug nut stripped i wouldn't hesitate to keep driving. But if I had a 4-lug wheel I'd be a lot more gentle in my driving.
Old Mar 8, 2023 | 12:02 PM
I would agree on that. Ill get this rig buttoned up in the coming days. Thanks to all again for the input
Old Mar 11, 2023 | 05:52 AM
Just an update because I dont like open ended threads without updates haha. Eveything was a success and its all put back together. Thanks again to all.
yotaman90
Mar 31, 2010 09:20 AM
elnino
Dec 10, 2008 02:12 PM
kcebes
Nov 28, 2007 08:16 AM
DanStew
Nov 19, 2007 07:13 PM
vegaskurt
10
Nov 17, 2005 10:01 AM
