cracked 22re block?
cracked 22re block?
ok, so..i replaced the head gasket on my 22re and i sent in my head to get it milled and pressure checked and everything came back good so i put it all together with all the right torque specs-i started it up and white smoke out of the exaust pipe, so then i checked where the water warms up the throttle body and placed a new seal and then there was water in the oil- the water is coming in on the third cylinder (which was where the head gasket was originally blown)-- my only guess is that either the head gasket didnt seal right (which i can see it being -new head gasket with a milled head should have sealed right), the engine block is cracked, or another place where water can reach the third cylinder maybe through the intake manifold somewhere-i know those blocks are impossible to crack but that is the only thing i really can think of?
the timing chain guides are new and the chain is tight, but i think that the water is coming through the third cylinder somewhere because i take out the spark plug and run the motor and water will shoot out? i did check the compression and it was 125 psi in the cylinder
When I bought my 4Runner it had a cracked block. It was in the very back on the water jacket around the cylinder. Almost impossible to see, but there was a faint coolant residue. The guy who built my new motor said it was the second one he had ever seen.
so what mine was was a warped block, i talked to a guy that fixes a lot of 22re and was told that 9 out of 10 times it is just a warped head but you will sometimes get a warped block- if the head is flat and the block is flat there should not be any white smoke coming out
There is a coolant passage near the intake runner to #3 cylinder (and #2 as well) which passes into the intake manifold and out to the heater core. If the intake gasket there is compromised, coolant can enter the #3 cylinder (and possibly #2).
