A couple engine questions
Old Nov 17, 2014 | 07:50 AM
Josh_Br's Avatar
Hi,
I have a 1990 pickup, 4x4. It has a 22RE from a 1992. I have a couple questions:
1) The engine makes a clicking sound that is relative to the RPM. I thought it was a rocker or valve, but tightening them a little tighter than normal did not make a difference. Then I got out the stethoscope, and pinpointed the sound to the right side of the water pump. I assume it is not the water pump, but actually a timing chain guide issue. Do you think that is probably the case?
2) The engine could use a new head gasket, as well as ^^^ fixed. I have been thinking about doing these two things at the same time, and also replacing the camshaft with one that provides more ponies. If I get a camshaft that provides more horsepower, would this require having the ECU reprogrammed/tuned, or anything like that?
Thanks,
Josh
Old Nov 17, 2014 | 12:29 PM
donomite49's Avatar
Could be a timing chain, might think about doing water pump at the same time
No you cannot flash a toyota Ecu, shouldn't need to retune for what you are doing.
Old Nov 17, 2014 | 06:34 PM
Josh_Br's Avatar
I was considering replacing the water pump too, while I have everything apart. Probably wouldn't hurt...
Thanks
bigjstang
Jun 2, 2025 03:56 PM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
Cplmike
Jul 8, 2015 08:47 PM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
