Correct plug for TE1 & E1 terminals?
Old Jun 11, 2024 | 10:44 AM
Borske's Avatar
Is this the correct plug to use to retard the engine timing? Other posts I've read show 2 round plugs in the engine bay. One for fuel and one for the timing. I have not seen the terminal portion to tell if this is what TE1 & E1 look like.
I have a 86 vintage 22RE engine that I am trying to set the timing on but I am unsure if this is the terminal to use to retard the timing from the ECU.
The engine and drivetrain are from a 86 pickup but are in a 55 willys truck so wiring is not exactly stock.
Thank you!
Old Jun 12, 2024 | 06:20 PM
osv's Avatar
osv
that looks like the correct two-wire connector, check it here:
https://www.4crawler.com/4x4/CheapTr...CheckConnector
Old Jun 13, 2024 | 09:49 AM
Borske's Avatar
Thanks for the reply. I only have the one round plug so I'm assuming its the correct one.
Old Jun 13, 2024 | 10:02 AM
osv's Avatar
osv
you'll know for sure when you short the connectors and see what happens with the timing marks.
chefdave
Nov 5, 2013 07:23 AM
Lons
Oct 16, 2012 05:39 PM
infamouslyb
Feb 23, 2011 04:18 PM
22RE-1987
Feb 16, 2010 01:30 AM
Packrat
Mar 9, 2004 04:41 AM
