Coolant leak in the back of 3VZE
Old May 2, 2011 | 09:40 PM
  #41
banoobee17's Avatar
does the coolant temp sensor have o ring thing like prevent it from leaking or can you put it on just like that. and the whole mount thing where all the sensors go have a gasket?
Old Jun 17, 2011 | 01:40 PM
  #42
urusai57's Avatar
Sorry to bring this thread back, but I'm having the same coolant leak problem.
Here are some pictures I was able to take. so cramped!
Not sure if you can see, but there's some coolant collecting in that nook behind that switch (i think its a switch), above and to the driver side of the U-hose.
any thoughts?
Old Jun 17, 2011 | 04:22 PM
  #43
toyotacharles's Avatar
that nook is a sut and nut that holds the sensor pack in, 1 of the 2 on it.
i dont see any drip trail from any sensors in the pic. my concern is hose or clamp seapage when warming up expanding
Old Dec 9, 2013 | 04:31 PM
  #44
CarSick?'s Avatar
Originally Posted by Bobzombie
Dont forget the coolant sensor bank behind the plennum up against the fire wall.
I would check this also. There are 4 sensors in there and you could have a leak there.
Also that sensor bank has a gasket and is bolted to the intake mani.
Coolant could be running down that right to the exh crossover pipe
I leaking coolant after rebuilding the top end. its definatly coming from the coolant sensor block gasket. I plan on removing the upper intake to replace the gasket. Heres my question, can i use the blue rtv instead of a paper gasket? Or is there something else i could try since i dont have another
Avenged
Jul 9, 2015 07:55 AM
colinmil
Jul 6, 2015 04:03 PM
MTLroadierunner
Jul 6, 2015 12:17 PM
HRDC0R19
Jul 5, 2015 06:43 PM
elwood73
Jul 5, 2015 07:07 AM
