Control arm leak?
Old Oct 25, 2013 | 05:17 PM
Daenerysdad's Avatar
Control arm leak?
So I was under my truck getting stuff prepped for my control arm swap, and I noticed a nice puddle of oil sitting just outboard of the shock mount. So just the passenge side shock and lower control arm are soaked in oil, nothing dripping from above, nothing else really saturated. Any thoughts? Blinker fluid blowing back from the bumper?
Attached Thumbnails Control arm leak?-d15627af-3878-4284-905b-5e7a4c319c65-1721-00000348b42e4c66_zpsa892b53c.jpg
Old Oct 25, 2013 | 05:23 PM
250000_yota's Avatar
I'd suspect you've either blown that shock, or split a cv boot. Those are the only two things that could really leak down onto the control arm right there.
Old Oct 25, 2013 | 05:26 PM
Well, I'll take either one of those. Replacing both tomorrow morning with a Bilsteins and t100 cv axles. But I'd suspect it's the shock, cause I checked the cv boot and it's fine.
Old Oct 25, 2013 | 05:36 PM
arlindsay1992's Avatar
Do you have a Pickup or 4Runner? T100 axles will not fit. If the boot isn't torn and the CV's aren't damaged why would you replace the half axle?
Old Oct 25, 2013 | 05:42 PM
I'm guessing since he mentioned the T100 axles specifically he's probably installing a long travel kit like a blazeland or total chaos.
'93 3vze pickup. Blazeland long travel getting swapped in, in a few hours. Just don't wane earl gettin' on the new shinneys!
Old Oct 25, 2013 | 09:43 PM
RSR's Avatar
RSR
Doesn't look like shock fluid -- it's more of a light oil in my experience.
Could also be a failed inner axle seal -- the one that seals the wheel bearings that you're supposed to replace when replacing axles.
Old Oct 26, 2013 | 07:45 AM
Stevesk88's Avatar
^ this is what i was thinking. If your in there you may as well do the seals for peace of mind.
88sasturbotoy
Jan 30, 2026 01:57 PM
kirkrunner
Jul 27, 2015 07:59 PM
gmonnie123
Jul 26, 2015 02:44 PM
ksmudrunner99
Jul 21, 2015 05:33 AM
1994toyota
Jul 17, 2015 03:03 AM
