Continuing 22R problems
Old Jun 14, 2006 | 02:09 PM
curtiswyant's Avatar
Hi y'all, got an '87 22R carbed truck 4spd having a few problems. I had idle problems where the truck would start but immediately stop. I replaced fuel pump and filter, dist cap and rotor, plugs and wires, and got the idle dialed in. Now, the truck has a bit of a consistent miss at idle and lurches/hesitates BADLY when warm. It will run better when warm, but still "runs like crap." I've had what I think are choke issues in the past where the truck will stumble and accelerate poorly when cold. I've checked for vaccum leaks and haven't found any. So I dunno what to think, I've sprayed carb cleaner around the carb/choke and intake to no avail. So, what could it be? Incorrectly gapped plugs, bad coil, slipped timing gear? Thanks for any help!
Old Jun 14, 2006 | 02:18 PM
celica's Avatar
have you checked the timing?
Old Jun 14, 2006 | 02:58 PM
Sure haven't. It's one of many things I'm gonna check (or re-check) tomorrow.
Old Jun 15, 2006 | 08:38 AM
Ok, checked and adjusted timing. It was a bit retarded. Truck seems to idle a little smoother now, but still sounds like it's missing out some. I haven't driven it yet since the adjustment...
Old Jun 15, 2006 | 09:37 PM
stock87's Avatar
Check the valve adjustments too. Those can make a big difference. .008 Intake/.012 Exhaust (hot)
Eggslinger
Jun 8, 2019 03:32 PM
young buck
18
Aug 27, 2018 02:40 PM
keithporter83
Jul 24, 2015 07:37 AM
PlayAwhile
Jul 20, 2015 11:36 AM
jackiebrownia
Jul 20, 2015 09:02 AM
