Continuing 22R problems
Hi y'all, got an '87 22R carbed truck 4spd having a few problems. I had idle problems where the truck would start but immediately stop. I replaced fuel pump and filter, dist cap and rotor, plugs and wires, and got the idle dialed in. Now, the truck has a bit of a consistent miss at idle and lurches/hesitates BADLY when warm. It will run better when warm, but still "runs like crap." I've had what I think are choke issues in the past where the truck will stumble and accelerate poorly when cold. I've checked for vaccum leaks and haven't found any. So I dunno what to think, I've sprayed carb cleaner around the carb/choke and intake to no avail. So, what could it be? Incorrectly gapped plugs, bad coil, slipped timing gear? Thanks for any help!
