connect/wire repair kits? Does Toyota make these?
Old Jun 2, 2014 | 08:25 AM
Mr. iNCREDIBLE's Avatar
both Chrysler and GM have wire and connector repair kits you can purchase to fix a damaged connector or wire harness, as opposed to buying the entire harness.
the connector on the igniter on my 3VZE has several broken wires at the base of the connector, I have jury-rigged it for now, but I would rather replace the connector and wires if possible without having to replace the entire harness.
I could possible make my own using the plastic housing I have if I can find a source to locate the internal pins.
any ideas?
Old Jun 2, 2014 | 08:41 AM
scope103's Avatar
While I haven't done it myself, others on this forum report that each plug has a Toyota part number (I hope you kept the parts of the plug you want).
This post shows how to replace the pins in a plug.
But if you want the wire repair kit, that's available too. http://www.handsontools.com/OTC-Toyo...-_p_40524.html
Old Jun 2, 2014 | 09:02 AM
awesome, thank you very much, the links in your first link give me exactly what I need..
voiddweller
19
May 2, 2016 09:10 PM
PureTacoma_Tundra
PureTacoma_Tundra
Jun 29, 2015 09:45 AM
rwh2toyota
13
Jun 27, 2015 05:39 PM
zytra
Jun 24, 2015 08:14 AM
95Runner
Jun 9, 2002 08:56 AM
