compression testing procedure?
Old Jan 5, 2007 | 03:41 PM
spacoli's Avatar
I did a comresssion test tonight on my 22re with a borrowed tester. I never did this before so I just did the following.
It was a snap-on tester and there was various hose fittings for different size spark plugs. I found the right size, but it did not have the valve core in it, some had the core in and some didn't.
So what I did was just watched the gauge jump up and down as the engine was turned over. I was getting 118psi one one cylinder and 120+ on all the others.
Should I have installed a valve core from one of the others hose fittings? It seems like that would just keep increasing the pressure in the gauge with each stroke?
What is the correct procedure for testing?
Old Jan 5, 2007 | 04:01 PM
eric-the-red's Avatar
Basic procedure for compression testing is to warm up the engine, remove the plugs, attach the guage, fully open the throttle late and turn the engine over about 5 times. I've never noticed if they have a valve core or not.
And the specs for a 89-95 22RE are:
Normal - 171 psi
Minimum - 142 psi
Max variation between cylinders - 14 psi
So if you're really getting around 120 then that's low.
Old Jan 5, 2007 | 10:38 PM
pruney81's Avatar
Sorry to hijack but do you know the specs for a 3.0?
Old Jan 5, 2007 | 11:05 PM
Alperovich's Avatar
the specs for the v6 are the same.
Old Jan 6, 2007 | 04:27 AM
drew303's Avatar
remove all plugs so the engine doesnt start correct? It's been a few years since i did a compression check to and my memory blows
Old Jan 6, 2007 | 06:21 AM
highway's Avatar
Yes and i always disconnect the coil wire that runs to the distributor.
Old Jan 6, 2007 | 06:50 AM
Alperovich's Avatar
you don't have to remove all the spark plugs, at once.
it wont matter since, you should disable the ignition system and the fuel system, by pulling the wire on the distributor and pulling the fuel pump fuse.
also in the service manual they recommend dropping a few drops of oil in the cylinder if the compression in a little low and/or if the truck has been sitting, you should have the engine warm (not hot) when you do this too.
Old Jan 6, 2007 | 06:56 AM
mt_goat's Avatar
From the 93 truck FSM, 22re engine:
http://personal.utulsa.edu/~nathan-b.../6compress.pdf
Old Jan 6, 2007 | 07:04 AM
mt_goat's Avatar
Yeah it sounds like your tester wasn't holding the compression from each stoke. It must have been letting the pressure out after each stoke. It should get a little higher each time it turns over until the max is reached, (maybe 5-7 strokes). Must have needed one of those valve cores.
Old Jan 6, 2007 | 07:06 AM
mt_goat's Avatar
From the same 93 truck FSM for a 3VZ-E
http://personal.utulsa.edu/~nathan-b...66compress.pdf
Old Jan 8, 2007 | 06:01 AM
maxpower_hd's Avatar
Definately put the pin in. I have the same tester too.
MAKE SURE the coil wire is disconnected COMPLETELY. While doing some electrical tests, I removed only one end and the tip was close enough to the coil that the damned thing still started.
Old Jan 8, 2007 | 07:42 AM
SLC97SR5's Avatar
Are the compression spec's for the 22-R the same as the 22-RE?
Old Jan 8, 2007 | 07:58 AM
I believe they are.
justdifferentials
14
Jun 11, 2017 08:36 PM
runnermedic
13
Sep 21, 2015 05:20 PM
_Nicco_
Sep 21, 2015 03:06 PM
TOYOTASC
Sep 10, 2015 05:18 PM
zz_denis
Sep 6, 2015 03:43 PM
