Compatibility of fan brackets
Old Jan 17, 2014 | 08:30 PM
Shoua's Avatar
My fan bracket is going bad, and I have a replacement (used) Toyota unit, but I am unsure if it's compatible.
My truck is an '89 4Runner with the 3.0 v6, but I have the spring-loaded tensioner version on my early year v6. The newer engine has the hydraulic tensioner version, and both fan brackets are slightly different. The replacement unit I have is from the newer v6.
Does anyone know for sure if they are interchangeable? I don't want to through the trouble of removing mine just for it not to fit.
Old Jan 17, 2014 | 10:53 PM
Chooch's Avatar
What is a fan bracket..?
Old Jan 17, 2014 | 11:35 PM
Punchy's Avatar
I am not formiliar with the hydraulic version but I ASSUME that you can tap the oil hole in the block and plug it.
Then use the non hydraulic version.
Anyone else have info on this.....
Old Jan 18, 2014 | 07:53 AM
Shoua's Avatar
It's the bracket that holds the fan and drive belts pulleys.
JUICE222
Oct 13, 2015 08:50 AM
irv
Sep 23, 2015 08:30 AM
runnermedic
13
Sep 21, 2015 05:20 PM
reallynotamechanic
Sep 20, 2015 05:40 PM
Aaron Logan
Sep 3, 2015 08:08 AM
