Cold weather issues!!!
Old Feb 17, 2015 | 08:32 PM
87blyota's Avatar
well here in Tn we've had some pretty crappy weather and today I was driving around and my 87 pickup with a 22r started bucking and when slowing down would try to die. It didnt do it when the engine was cold but after it warmed up. If I give it a quick rev itll die sometimes and I got it to backfire once. After it dies I have no problem starting back up like if I'm braking all I have to do is start it again and give it a little gas until I get going again. I have checked the AAP and there was no fuel in the vacuum line. I read that it could be the Idle cut solenoid. Just looking for ideas on what to try. I just put on new plugs, wires, rotor, and coil about a month ago. talked to a mechanic and he said it might be carb icing sense it is barley in the 20s and we had almost 90% humidity today dont know anything about it but just add it to the pile of reasons.
Old Feb 17, 2015 | 11:50 PM
wyoming9's Avatar
Red face
Are you still using the stock air cleaner ??
I have seen so many aftermarket air cleaners freeze in conditions like you describe.
Old Feb 18, 2015 | 12:16 AM
grumpin's Avatar
First thing I thought of is carb ice. The right conditions for it. And as Wyo said aftermarkets can be prone to do that.
Old Feb 18, 2015 | 05:41 AM
87blyota's Avatar
No it's a after market one with the stock carb
Old Feb 18, 2015 | 08:25 AM
87blyota's Avatar
went and did some snow wheeling this morning and had no issues.
Old Feb 18, 2015 | 08:59 AM
dropzone's Avatar
Fossilized
Never had a problem in alaska with my old 84 with the stock air cleaner and preheater tube..
Old Feb 18, 2015 | 09:12 AM
87blyota's Avatar
The whole issue was really weird but I've been out and about for the past 4 hours with no problems
Old Feb 18, 2015 | 01:32 PM
grumpin's Avatar
If there is no heat going to the air cleaner and now it's fine, I would say you had carb. ice.
bigjstang
Jun 2, 2025 03:56 PM
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
shisha1999
Sep 21, 2015 08:22 PM
calderp
Jul 27, 2015 09:58 AM
britishdudes2dr
Jul 25, 2015 06:47 AM
