cold start good, wont start after driving
Old Jun 24, 2017 | 11:41 AM
GMartin1991's Avatar
Hello all,
I have a 1991 pickup v6 3vze. Just had my engine rebuilt and everything seems to be running smoothly. I searched here but could not find any answers.
With the engine cold, my truck starts up no problem. I can turn it off and on repetitively without any issues. After i have driven my truck and the engine gets into normal running temps, if I turn my truck off, it will not turn back on. Thinking about just getting a new starter but don't want to get a new one just to get one. I want to solve the issue. Is this a heat shielding issue?
Any suggestions would be greatly appreciated.
Old Jun 24, 2017 | 12:32 PM
millball's Avatar
There's a big difference between 'won't start' and 'won't crank' What is your issue???
Old Jun 24, 2017 | 01:31 PM
wallytoo's Avatar
if the starter you have is able to crank the engine, even if it won't start, putting a different starter in will not solve your problem (unless the present starter only cranks the engine very slowly).
diagnose the problem before condemning perfectly good parts.
Old Jun 24, 2017 | 04:15 PM
RAD4Runner's Avatar
COMPLETELY DESCRIBE YOUR TRUCK and put it on your signature. Will save everybody time having to ask you and waiting for reply.
A problem well-stated is a problem almost solved.
MODEL-YEAR-ENGINE-TRANSMISSION Yes. transmission means a lot when troubleshooting.
As the guys said above^^^
Toyota components are bullet-proof. The problems are often caused by poor assembly/wiring.
IF your issue is not cranking as opposed to no "VROOM", Start with this inexpensive test... https://www.yotatech.com/forums/f199...l#post52367443
Then, find your starter relay
AND get a multi-meter. Next only to our senses (common included), it is the most important troubleshooting tool.
Old Oct 2, 2020 | 03:05 PM
pimacdaddy's Avatar
Ok so Im able to run tests without the gauge ? I was hoping to be working on my issue tomorrow and order the gauge during the week.
Old Oct 2, 2020 | 03:21 PM
wallytoo's Avatar
what gauge? there isn't one mentioned in this thread
Old Oct 2, 2020 | 03:38 PM
pimacdaddy's Avatar
What the hell this is ain’t my thread ?? How did I ended here. My bad
dmrispoli
Nov 13, 2019 07:43 PM
tootalllewy
Jul 30, 2012 11:20 AM
alteredvision
Jan 8, 2010 01:08 PM
GLittler
Sep 8, 2009 01:30 PM
long travel yoda
Jan 2, 2008 03:43 PM
