code 14 what is it?
Old May 3, 2008 | 04:47 PM
94toy4x4fever's Avatar
code 14 what is it?
Have stored code 14. On a 94 toy 22re. Dont know what it is.
Old May 3, 2008 | 05:12 PM
abecedarian's Avatar
It means 'a loss of IGF signal between the ignitor and the computer for 6 events'. In other words, the computer expected a signal that the plugs were firing but couldn't tell they did 'fire' or 'spark' for 3 rotations of the crank (6 spark events). More importantly, it means that the computer, for whatever reason, did not detect a proper 'spark' and 'combustion' event for a long enough period of time to signal a serious problem.
Most likely, it is the ignitor (the black box on the ignition coil) but could also be the wiring from the ignitor to the ECU or the ECU itself.
Are you experiencing any engine performance issues?
Old May 3, 2008 | 05:22 PM
chrishf12's Avatar
I have had the same issue but it would come and go. I would like to know what you find your problem to be.
Old May 3, 2008 | 05:26 PM
I dont have a loss of power but the truck does ping alittle bit. Even on high octane gas
Old May 3, 2008 | 05:29 PM
Maybe I should back up a little and ask if the check engine light has come on at all recently?
It's possible that the code was triggered a while ago but hasn't happened since and is only showing up because the codes are stored.
Old May 3, 2008 | 05:38 PM
check engine light came on a few months back. It was a code 71 egr. No this code was a stored code that I pulled after taking a drive. Just was curious to see if there was any stored codes.
Old May 3, 2008 | 05:41 PM
Truck also dosent like to start after it gets hot. I have to crank it then wait the crank it again. It usually takes a little to get it fired. WHEN HOT. Fires right up when its cold.
Old May 3, 2008 | 05:58 PM
If it's a 'stored code' as you say, I wouldn't worry about it. Like I said, it basically meant that the computer didn't detect spark plugs firing for a few engine revolutions. That is totaly unrelated to what you're experiencing now.
Hot start problems with fuel injected vehicles are usually related to fuel pressure regulators and check valves.
Old May 3, 2008 | 06:06 PM
ok thanks man u have been great help!
Old May 3, 2008 | 06:10 PM
Maybe a fuel filter change is in order.
Old May 3, 2008 | 06:41 PM
put new fuel filter in when I put the engine in 2 months ago and it only got 1200 miles on it right now
moparbay
Oct 6, 2015 09:24 AM
bradahman
Oct 1, 2015 09:24 AM
charlie_fong
Sep 27, 2015 10:06 PM
Odin
Sep 26, 2015 06:56 PM
Draven023
Sep 26, 2015 12:41 PM
