code 11 question
code 11 question
So I have an 86' 22re 4x4 m/t and I'm pulling a code 11. The manual says it's either the:
1. A/C switch
2. throttle position sensor
3. throttle position sensor curcuit
4. ECU
I just finished rebuilding the motor and when I start it it won't idle. It just lopes down until it stalls out if I let off the gas. If I hold the gas it runs but misses a lot. I have yet to adjust the timing and tune a few more things I was just curious as to if anyone knew the likely culprit.
1. A/C switch
4. ECU
Check the Throttle Position Sensor:
- http://www.4crawler.com/4x4/CheapTricks/TPS/index.shtml
nframe
3.4 Swaps
Aug 16, 2015 09:03 AM
