code 11 question
So I have an 86' 22re 4x4 m/t and I'm pulling a code 11. The manual says it's either the:
1. A/C switch 2. throttle position sensor 3. throttle position sensor curcuit 4. ECU I just finished rebuilding the motor and when I start it it won't idle. It just lopes down until it stalls out if I let off the gas. If I hold the gas it runs but misses a lot. I have yet to adjust the timing and tune a few more things I was just curious as to if anyone knew the likely culprit. |
bumpity:nerd:
ba ba bump
Check the Throttle Position Sensor:
- http://www.4crawler.com/4x4/CheapTricks/TPS/index.shtml |
The TPS :think:
4crawler-thanks man
