Clutch replacement now no 5th gear.....
Old Apr 14, 2015 | 01:17 PM
jcboal's Avatar
New here. Always wanted a toyota pickup, and now I have a 1991 3.0 5 speed.
I replaced the clutch and lost 5th gear.
Replaced the shifter bushings, no luck.
I have read of others having the same issue, but never any resolution on how to fix it, or what is wrong with it.
Any help would be appreciated.
Old Apr 14, 2015 | 01:23 PM
millball's Avatar
May be a problem with improper positioning of the shift rails when reinstalling the shift lever.
No clutch problem would isolate itself to just 5th gear.
Old Apr 14, 2015 | 01:28 PM
jcboal's Avatar
I figured it wasn't related directly to the clutch.
I pulled the shifter 3 times trying to adjust its position when bolted down, but never made a difference.
Old Apr 14, 2015 | 02:33 PM
JasonYota's Avatar
Will the shifter go into 5th at all?
Old Apr 14, 2015 | 02:39 PM
jcboal's Avatar
Nope, it just grinds as if it won't quite go into gear
Old Apr 14, 2015 | 05:01 PM
JasonYota's Avatar
What about with the engine off?
Old Apr 14, 2015 | 05:31 PM
jcboal's Avatar
It sounds like it is going into 5th and feels like it with the engine off
Old Apr 14, 2015 | 11:48 PM
sr5tyler's Avatar
Did you replace the fluid?
Old Apr 14, 2015 | 11:53 PM
wyoming9's Avatar
Red face
Did you by chance get the shifter in backwards ??
So very easy to do speaking from me seeming to do it every time.
Then the shifter hits the floor before going into 5th gear.
Old Apr 15, 2015 | 05:00 AM
jcboal's Avatar
Yes i did change the fluid.
The shifter is installed properly and not hitting the floor.
Old Apr 15, 2015 | 05:37 AM
thefishguy77's Avatar
I believe it is definitely related to something you did. Might be you have to look at everything you touched with a "what did I screw up" questioning. Not saying you did. But I find when something breaks after I work on it. It's usually related to something I did.
Old Apr 15, 2015 | 06:27 AM
jcboal's Avatar
I agree that it is something I did....but the only things I did were the shifter bushings and the clutch, haha.
I have removed the shifter several times to make sure it was re-installed properly and all of the other gears work fine, including reverse. (leading me to believe it is not a clutch issue).
I am just looking for ideas on what i am missing.
Thanks!
Old Apr 15, 2015 | 06:42 AM
Terrys87's Avatar
On a 22r tranny, I have put the rear end on jack stands and then with the shifter stick out, have manually shifted the tranny with a large screw driver. I am guessing a 3.0 tranny is the same. When shifting it with a tool that will work for you, you will need to slide the shifting assemblies to the drivers side to find 5th is the best that I can explain it. Up and Down would be the same, oppisite of the shifter its self.
1st gear would be on the passenger side and 5th would be on drivers side. The shifter tilts basically and moves the assembly oppisite of the shifter. It would at least let you know if 5th is actually working and may be it is the stick not seated correctly.
smthwsn357
May 1, 2024 07:28 AM
mskalmus
May 28, 2017 07:51 AM
Sep 4, 2015 09:27 AM
msane99
Jul 17, 2015 10:13 AM
Kalihi,HI
Jul 9, 2015 04:29 PM
