Clutch help needed ASAP
Old Jan 30, 2010 | 09:22 AM
BMC's Avatar
BMC
Im in the middle of replacing the clutch in my 87 4runner. Im installing a marlin crawler hd clutch and i have no idea what direction the cluth goes on the flywheel. It seems to fit up against the flywheel both ways. Its different from the oem clutch that came out of it. The center of the clutch that slides over the splines sticks off of the clutch further on one side. On the oem cluth the center part sticks out further on the opposite side of the clutch. Any help would be greatly appreciated.
Old Jan 30, 2010 | 04:22 PM
flyingbrass's Avatar
I looked at mine and see what you mean. The old disc has a lot more of that splined portion sticking out on the flywheel side.
When viewed from the edge, the flat side faces the flywheel. This isn't a very good picture, but it's the only one I have. I picked the disc up off the pressure plate. The side thicker due to the springs goes toward the pressure plate.
I presume the one from Marlin goes on the same way.
Old Feb 3, 2010 | 04:27 AM
MAINETOY's Avatar
never used a marlin clutch but generally the clutch disc hub and spring assembly would face the tranny.
Old Feb 3, 2010 | 05:54 AM
Wes94's Avatar
I put in a Marlin HD clutch and yes the flatter side goes to the flywheel.
Old Feb 3, 2010 | 06:59 AM
MAINETOY's Avatar
whos the manufacture on the marlin 1200lb clutch?
Old Feb 3, 2010 | 07:06 AM
Wes94's Avatar
the disk is AISIN. i think they use components from a few different companies for the pressure plate. Mine is 2100lbs
Old Feb 12, 2010 | 07:15 PM
CRF_450R's Avatar
i ordered a clutch kit from marlin crawler and what do ya know they send me the wrong damn thing, it only took a week for the damn thing to get here and now i have to wait four more days until theyre open again due to presidents day and some offroad event they went to today and closed shop. i went to napa and got a new one today. marlin crawler uses "seco" clutches and pressure plates
bigjstang
Jun 2, 2025 03:56 PM
Kalihi,HI
Jul 9, 2015 04:29 PM
Jnkml
Jul 6, 2015 01:20 PM
zd92655
Jul 5, 2015 04:25 PM
Vargntucson
Jul 4, 2015 12:15 PM
